full plug and play computer
Mitsiman
Approved FTO Australia Trader
Re: full plug and play computer
Post by Mitsiman »
Unless the emanage has tapped into and modified the variable inlet manifold controller, I woudl not think so.
To be honest I still don't beleive the emanage ultimate is good enough to tune the car properly. The combination your running is so far outside of its ability, you can only mess up a factory ECU so much before you spend so much time trying to trick it that it ends up a mess.
I am not surprised the injectors are maxing out. Get some 210cc units or 275cc units from a Magna 3.0 or 3.5 V6. They bolt straight in and will be more than large enough for any N/A setup on these vehicles.
