Aftermarket Replacement Parts
Posted: Fri Jun 18, 2010 4:53 pm
OK, Figure that this topic should have been created as a sticky ages ago. I keep getting asked for belt part numbers and things like that. Feel free to correct them if they are wrong.
Headlight bulbs:
Low Beam: HB4 51W
Low Beam (HID): D2S (D2C also compatible)
High Beam: HB3 60W
Front foglights (Series 1): H3 55W
Front foglights (Series 2): H3 55W
Front indicators: S-25mm 21W
Side indicators: T-10mm 5W
If editing this post, ive found that copying the
Code: Select all
What Brand Suits Where ~Price
Mivec timing belt (GPX) Gates T987 (232 teeth) GPX,GPvR Most Auto Stores ~$100
Non-Mivec timing belt (GR) Gates T954 (226 teeth) GR Most Auto Stores ~$100
CV Boots HJ Galant ? All Most Auto Stores ~$20 each
Steering Rack Boots HJ Galant All
Timing Belt Idler Pulley Koyo PU307034ARR1DW GPX?
Timing Belt Tensioner Pulley Koyo PU106218FRRID GPX?
Power Steering/Aircon Belt 6PK1080 All?
Alternator Belt 4PK940 All?
Iridium Spark Plugs NGK BKR7EKC-N-11 All?
Oil Filter Ryco Z411 All?
Front disks HJ Galant 2.0L V6 GR
Front pads HJ Galant 2.0L V6 GR
Front disc pads Intima SR6300 (MD-6039M) GPX
Rear disc pads TRW DB1278 All?
Front struts Same as S40 Volvo
Air Filter K&N: 33-2072 All
Air Filter RYCO: A1318 All
Air Filter Bosch: S 3968 All
Front Rotors (Stock) DBA425/RDA425 GPX,GPvR
Front Rotors (Slotted) DBA425S/RDA425S GPX,GPvR
Front Rotors (Slot-drill) DBA425X/RDA425X GPX,GPvR
Strut Tops Same as CE Lancer All Pedders ~$70 each
Lower Engine Mounts (Rear) EVO 1-3 All http://www.meek.com.au/index.php?act=viewProd&productId=256
Lower Engine Mounts (Front) EVO 1-3 All http://www.meek.com.au/index.php?act=viewProd&productId=250
Low Beam: HB4 51W
High Beam: HB3 60W
Code: Select all
section into notepad does a fairly good job of retaining spacing.
cheers
