Weapon-R Dragon intake
- spetz
Re: Weapon-R Dragon intake
For $380 it does not seem worth it
Why not get an aluminum one made up for a fraction of the price?
Yes, I agree, thats why I asked if anyone knows of an Aus supplier, could be cheaper.
But it does look awesome
I could probably get an ally one made at work for beer
- spetz
Wondering if something like this would fit:
http://www.ebay.com/itm/TEGIWA-CARBON-F ... 27c6c58d34
Of course the battery would have to be moved
Haven't we been through this?
- spetz
It was a different intake
Just have to keep in mind, moving the battery to the boot, isn't like throwing a strut brace on, its something that needs to be done to ADR specs & requires an engineers certificate to be legal. Correct gauge wire, correctly fused, sealed battery, mounted appropriately etc etc
- spetz
Yes of course.
I didn't realize it needed to be engineered though
Tip:
90deg 3" silicon bend
45deg 3" sillicon bend
Go to an exhaust shop get them to cut a half metre stainless section of pipe.
2x clamps
Podfilter
-put it all together.
Yes the stainless steal absorbs heat, but guess what so does the massive intake manifold that is bolted directly to your hot engine.
2x clamps
Podfilter
- spetz
Any reason why it should be 3"?
I found 4" to 3" 90 degree reducers and was wondering whether this would be good for the intake, that way a 4" pipe can be used and it would funnel down towards the TB
Try and find an exhaust shop with 4" piping let alone a pipe bender that can fit it 4" pipes in it.
In the end its only gotta go thru the smaller 3" TB.
- spetz
Yes but it will have lesser restriction and the narrowing down will increase intake velocity which is good for power.
4" aluminum piping can be bought pretty easily, and the bends can be silicone.
