Engine Oil
Engine Oil
Hey guys,
not sure if this has been covered or not but i cant find it on the forums.
I am currently about to do a 125k major service on the car, and im using 5-30 fully synth in it atm.
My question here is: has anyone tried, and noticed a beneficial difference between say 10-40 and 0-40?
My engine is running pretty damn good, and i dont think ill hit any leaking problems if i switch down to a 0 rating, but i was just wondering if the Mivec FTO if at all can benefit more from a thinner synthetic oil over a thicker one.
I was looking at the castrol edge sport 0-40 full syth to put in - anyone here running that at the moment?
While im here - is there a specific filter anyone recommends with it?
Valandis91
Re: Engine Oil
Post by Valandis91 »
Im using martini racing 0-40w oil at the moment and it loves it.
reset the battery at the same time and it runs sooo much better afterwards.
mines done close to 176xxxkm's and its running good.
For filters use k&n. HP 1006 or 1010 will do the job. i think....
Re: Engine Oil
Sweet - cheers
Will tell the boys at Joe n Ricks to reset the battery and ill pick up one of those oil filters
bduffman
Re: Engine Oil
Post by bduffman »
by from what ive herd joe and ricks know there sh*t
so im guessing they would know the best oil and filter to use
evoman
Re: Engine Oil
Post by evoman »
Mate, oils are so damn complicated who knows what's best - everyone has differing opinions.
One thing though;
You do realise what the listed viscosities mean don't you?
If you went for a 0w-40, yes your oil your oil would be thinner at startup, but once warmed up, would be thicker than what you currently have.
Some people also believe it is best to minimise the difference between cold and warm viscosities as the bigger the difference, the more viscosity modifiers are required.
I did read once on here that someone was adamant that their car loved thinner oils like a 5w-30, especially when MIVEC came around, but again, who knows.
Unless you live in a really cold climate, I think you would see no benefit from a 0 grade oil.
Re: Engine Oil
Valandis91 wrote: reset the battery at the same time and it runs sooo much better afterwards.
WTF :?
I take it you are talking about the ECU, but even then why?
You are only changing oil.
Valandis91
Re: Engine Oil
im not saying it had anything to do with the oil. it just run a lot smoother after the ecu reset.
Re: Engine Oil
Tried some nylon synth 10-40 expensive sh*t but no good on the litters.
Who's tried tried a thicker 15w oil?? Better for start up noise???
Re: Engine Oil
Vlandis, how much you pay for the Martini 0W40?
Valandis91
Re: Engine Oil
Shane001 wrote:Vlandis, how much you pay for the Martini 0W40?
$72 for 5 litres
Re: Engine Oil
Where'd u get it from?
I need a new oil. Was using Penrite Sin 15 (15W40) but the morons have decided to 'add 10' to all their premium oils! So it's now a 15W50!
Idiots... :evil:
Re: Engine Oil
Is that the Sint 40 R/T?
Valandis91
Re: Engine Oil
Shane001 wrote:Where'd you get it from?
Idiots... :evil:
that does sound quite thick.
Yeah it is the SINT 40R/T
i definitely recommend it.
