It's about Brakes!
- Gholdwayne
It's about Brakes!
With the search function having amnesia I cant search for more topics any better than what i'm doing now, skimming through sections!
Anyways, I thought It'd be good to start a thread for FTO brakes, or brakes in general.
First off, Brake fluid.... My pads have been replaced on all four corners, and slotted rotors on the fronts put in... Only thing left is to service the brake fluid....
Soooo... Is the correct amount of fluid 1L ? Im also interested to know what brand of fluid is good to use...
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
FTO[For The Orgasm]
- phunkydude
Re: It's about Brakes!
Motul dot 5.1 seems to be the recommended ones.
- Gholdwayne
for FTO's yes? can be?
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- Dras
I went with TRW GP600 Dot 4 Racing Brake Fluid as a track day fluid.
I used Nulon Extreme Performance Brake Fluid - Dot 4 prior to this.
- Gholdwayne
I suppose I'll just go with the Nulon Extreme Performance Brake Fluid - Dot 4
Easier to get(autobarn, etc).
So i'll need 2 500ml bottles yes?
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- bass_twitch
When you doing your fluids?Gholdwayne wrote:I suppose I'll just go with the Nulon Extreme Performance Brake Fluid - Dot 4
- Gholdwayne
Asap. When I find the time... maybe tomorrow early morning? Im buying the fluids at 2pm today, my lunch, at Penrith 'theBarn.
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- Dras
Depending on how bad your current fluid is, you might be able to get away with one, but for the price you may as well get 2.Gholdwayne wrote:I suppose I'll just go with the Nulon Extreme Performance Brake Fluid - Dot 4
You can always use the leftovers to bleed the clutch.
- bass_twitch
Is it a hard/big job?Gholdwayne wrote:Asap. When I find the time... maybe tomorrow early morning? Im buying the fluids at 2pm today, my lunch, at Penrith 'theBarn.
How do you know when you need to change them?
- Gholdwayne
I think every 60,000k? phark if i know tbh
Apparently its not too hard a job, but it can get messy without the right things... I just felt like changing the brake fluid for peace of mind. And with a mechanic so I can watch how its done...
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- bass_twitch
Oh, so you aren't DIYing it. hahaGholdwayne wrote:I think every 60,000k? phark if i know tbh
well if you learn how to do it, you can share your knowledge with me.
- Dras
Every 2 years I would change the fluid or before a track day.
Not a hard job at all and there is plenty of info on google / youtube about bleeding the brakes.
- Gholdwayne
Might get it done at like 8am tmorw then join you in your tyre appointment Might even pop in to the same shop ! Lol!
Dras, totally forgot about youtube! Oh, and its been 2 years already since i the fluid was changed..
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- bass_twitch
sounds like a date ?Gholdwayne wrote:Might get it done at like 8am tmorw then join you in your tyre appointment Might even pop in to the same shop ! Lol!
- Gholdwayne
Unfortunately I called in, no more mechanic spots Just gonna go to my old mechanicbass_twitch wrote:sounds like a date ?Gholdwayne wrote:Might get it done at like 8am tmorw then join you in your tyre appointment Might even pop in to the same shop ! Lol!
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- Gholdwayne
So who here uses DOT 5.1 fluid in the FTO? And what are your findings?
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
- Dras
DOT 5.1 fluid is simply a DOT 4 fluid with a higher boiling point.
For standard street use, a DOT 4 is fine. For track use, the TRW GP600 Dot 4 Racing Brake Fluid has a higher boiling point than the Motul DOT 5.1.
- Gholdwayne
Thanks Dras! I'll go with the Nulon Extreme
97 GPX Icelle Blue
FTO[For The Orgasm]
FTO[For The Orgasm]
