d_dan's Time Attack (Turbo FTO)
- d_dan
If somone could sticky this for me please.
With the amount of work and money put into my FTO I need to give it some serious track time so I have decided to take part in Time attack 2012.
Ill start it off with some pic's of the car first.
The Spec
Engine
Magnicor Plug leads
Blitz Grade 8 irridium plugs
Vernier camgears
VF35 turbo
Trust 13 row oil cooler,
350c injectors,
Greddy Emanage BLUE
Evoscan data logger.
Trust Fuel pressure regulator
PAR forged pistons
Modded CRX twin core Aluminium Radiator
Exhaust
Custom manifolds,
Custom downpipes,
Custom turbo intake pipe,
Custom turbo exhaust pipe,
Decat
5zigen Pro racer A spec cat back
Suspension & Gearbox
D2 Coilovers
D2 adjustable topmounts
Upper front strut bar,
Upper rear strut bar,
Exeddy 3 puck padlle clutch,
LSD
Brakes
Steel braided hoses front and back,
Yellow stuff pads (Front & back),
Alcon 6 pot brakes
Mitsubishi EVO 330mm Disks
3G rear disks
Interior
Sparco Bucket Seats,
Carbon fiber boot to interior devider
Exterior
Carbon Kevlar bonnet,
Carbon fiber bootlid,
Carbon fiber engine bay dressup
Bozz facelift pumper,
Pro shop rear apron,
Pro shop side skirts,
Carbon Fiber Splitter's
Carbon Fiber bellypan
Tyres
BRIDGESTONE RE 070 225/45/17,
The season starts in March and by then I need to have
Toyo R888's,
For trackday's I also use rally slick's & wet's
6 point roll cage
Stand alone ECU with anti lag
The Spec
Engine
Magnicor Plug leads
Vernier camgears
VF35 turbo
350c injectors,
Greddy Emanage BLUE
PAR forged pistons
Exhaust
Custom manifolds,
Custom downpipes,
Decat
D2 Coilovers
LSD
Brakes
Alcon 6 pot brakes
3G rear disks
Interior
Exterior
Tyres
Toyo R888's,
6 point roll cage
- Shane001
Re: d_dan's Time Attack (Turbo FTO)
If u're going to do serious track work you will need a better rear wing also.
And if you're serious the R888 is probably not the best tyre. It's more an endurance tyre lol. You want something sticky that's more suited to a qualifying tyre, maybe a Dunlop DZ03G in the softest compound, or a lot of the Time Attack runners in oz run the Yokohama 050, but expect these to go off pretty quick.
We are you looking to run it? Links to the series?
- d_dan
The problem over here is that it rains 362 days of the year. Also there is limitations on the tyres. In club class they are only allowed road tyres.
Ill be in pro class which means i can use a track tyre but there are still limitations. If i want to use any race tyre i will need to go up to ultimate class and tjen im against space frames etc.
I plan to use this season to just break myself and the car i.
- spetz
How does the car put down the turbo power?
And what cars do you compete against? How does yours compare?
- Shane001
The tyres I mentioned are all semi slicks, so would normally all be in the same type of class as the R888.
- d_dan
The class i will be doing is the pro class which allows trackday tyres and allows body modification ie. Carbon fiber pannels.
And i will be in the 2wd sub division.
2012 will be the first year they will split the 2wd and 4wd's
The cars ill be competing against are the likes of honda integra's, civics, CRX's, toyota starlets, galanza's and probably some other things.
In regards to getting the power down its a mix between power and traction. I need to get as much powe as i can to pull out of the corners into the straights as my car is a lot heavier than the 800 kg hondas. Ill have it out later in the month to setup the handeling and will know where i stand then.
Hopefully the bigger breaks and power will help counter the weight of the car.
As fas as i know i will be doing 4-5 sessions on mondello park national circut and 1-2 sessions on mondello's international circut.
You can take a look at the current season on the time attack app on the android market
- spetz
I assume your weight penalty will be hard to make up for.
How do you see your car compare to the rest you are competing against? Any visible pros and cons between all these cars in comparison to yours?
- d_dan
To be 100% honest this season i will be winging it. Im in the pro class rather than the novice class so im up against the seasoned vet's and a lot of cars built by tuners.
My main advantage looking at theis years competition is that where i may not come in the top 3 i see that some of the fastest cars get 1-2 really good rounds and then miss 1-2 rounds getti.g rebuilds etc as they blow turbo's, gearbox's and engines. So if i finish up in the upper middle table at the end my consistency will stand to me.
If i fine tune my breaking ill have an advantage as i am head and shoulders above the others in that department.
Weight is my downfall but once the cade goes in the grinder will be comming out.
And if i think that itll make that much difference ill make some carbon fiber door's.
- spetz
Do you know how much the doors weigh?
Have you had your car weighed?
- d_dan
All going well will have it weighed next weekend.
Weight reduction's
-rear seats removed
-rear pannels removed
-oem front seats removed
-oem bonnet removed
-oem boot removed
-spoiler removes
- spair wheel jack etc removed
- air con removed
- ac pump removed
- oem radiator removed
-oem exhaust removed
-oem pistons removed
-oem conrods removed
-oem manifolds removed
WEIGHT ADDED
-turbo
-stainless manifolds
-stainless downpipe
-Stainless turbo intake & exhaust
- 5zigen pro racer exhaust
-decat
-bozz front bumper
-carbon kevlar bonnet
-Alloy pistons
-Forged rods
-carbon fiber bootlid
Carbon fiber bellypan
-cobrau bucket seats
Weight reduction's
-rear seats removed
-oem bonnet removed
-oem boot removed
-spoiler removes
- air con removed
- ac pump removed
WEIGHT ADDED
-turbo
-stainless downpipe
-decat
-bozz front bumper
-Alloy pistons
-Forged rods
- d_dan
With the engine build finally finished I thought I would put a final Spec & some more pic's
[center]
Engine
Magnicor Plug leads,
Blitz Grade 8 Iridium plugs,
Custom Vernier camgears,
VF35 turbo,
350cc injectors,
Polished Aluminium Mocal oil cooler,
Modded Polished twin core aluminium radiator,
12" performance slimline fan
Greddy Emanage BLUE,
Evoscan data logger,
Trust Fuel pressure regulator,
ARP head stud kit,
PAR forged I Beam Conrods,
Custom designed CP Forged Piston's, piston ring's & gudgon pin's,
(reducing compression to 8:1)
Blitz SSQV black edition dump valve,
Custom modded Blitz Front mount intercooler,
Modded Blitz hardpiping kit,
Apexi power intake cone filter,
Wire tuck,
All pipework replaced with samco hoses/ Braided steel hoses.
Exhaust
Pro shop idia equal length stainless manifold,
Pro shop idia sainless downpipe,
Custom stainless turbo intake & downpipe,
Decat,
5zigen Pro racer A spec cat back.
D2 Coilovers,
D2 adjustable topmounts,
Exeddy 3 puck paddle clutch.
Phantom grip LSD.
C's Shortshifter
Brakes
DOT 5.1 break fluid
EBC Yellow stuff pads (Front & back),
Alcon 6 pot brakes
Mitsubishi EVO 330mm twin Disks
3G rear disks
Interior
FAI Sparco Bucket Seats,
Sparco 4 point harness's,
Carbon fiber boot to interior divider,
Completely stripped,
Wheel well removed.
Exterior
Bozz facelift bumper,
Carbon Fiber splitter's,
Carbon Fiber bellypan,
Carbon Fiber Replacement Headlight cap's,
Evo X engine cover
6k HID low beam's
6k HID high beam's
Carbon look Aerocatch's
Alloys & Tyres
Hubsentric wheel spacers
OZ chronos
Toyo 888 235/45/17 Front
Toyo 888 225/45/17 Rear
Electronics & Gauges
Apexi RSM Black Edition
Apexi Turbo timer
AEM Boost pressure gauge
AEM Air Fuel ratio gauge
AEM Exhaust Vaccum gauge
Oil temp gauge
Oil Pressure gauge
Fuel pressure gauge
[/center]
[center]
Engine
VF35 turbo,
350cc injectors,
ARP head stud kit,
Wire tuck,
Exhaust
Decat,
D2 Coilovers,
Phantom grip LSD.
C's Shortshifter
Brakes
DOT 5.1 break fluid
Alcon 6 pot brakes
3G rear disks
Interior
Wheel well removed.
Exterior
Evo X engine cover
6k HID low beam's
6k HID high beam's
Alloys & Tyres
OZ chronos
Apexi Turbo timer
Oil temp gauge
Oil Pressure gauge
Fuel pressure gauge
[/center]
- bass_twitch
Why do you uk Guys get to have all the fun?
That thing is a beast!!
Im keen to see the Evo cover go on!
Only thing I would change is I would put on a Gpvr wing
Great job mate!
Great job mate!
- d_dan
I removed my version R wing.
I prefer bear ass over all spoilers but I could be convinced to put one back on for a Carbon Fiber version R spoiler.
The way I look at it.
Richard batty has done Most powerfull VR4 converted FTO and EVO powered FTO
I would like to chase Most powerfull 6A12 FTO powered FTO
- spetz
Who will chase the most powerful all motor FTO???
- d_dan
Richard batty was that with his new bhild aiming for 1,000bhp
- Valandis91
What is he doing in this new build of his?
P.s i believe All Motor means NA
- d_dan
Nope its an evo engine so its got a blower
- Shane001
Well if Time Attack in Ireland has corners you're gonna need a rear wingd_dan wrote:I prefer bear ass over all spoilers but I could be convinced to put one back on for a Carbon Fiber version R spoiler.
- d_dan
I probably will need something.
Although the track they use isn't all that fast. with reaching maybe 140kph on the main straight on average
- aza013
- NSW Coordinator
100% agree. I have done a day on the track with no wing and I have to say the ass end dances all over the place. A good wing helps big time.Shane001 wrote:Well if Time Attack in Ireland has corners you're gonna need a rear wingd_dan wrote:I prefer bear ass over all spoilers but I could be convinced to put one back on for a Carbon Fiber version R spoiler.
