Help! What are these wires?
Hi guys,
I found all these harnesses/wires that I have no idea what they do in my car.
Can anyone tell me what they are?
The wires in question are circled in red.
A.
These are under the dash in the center, sort of behind and under the head unit:
B.
This is a wire with a plug right next to the throttle body:
And these are right next to the window wiper motor:
Thanks
Re: Help! What are these wires?
First one looks like where an auto tranny ECU was removed. Dunno about the other two.
Best bet would be to look em up in the electical manual.
I think that manual is too big to go through for this, especially considering this isn't an FTO.
Bennoz how sure are you about the auto ECU?
As I thought the auto was still a single ECU (ie motor + gearbox ECU)
No not one ecu they run an ecu for box and one for engine, it could also be air bag as well.
Dunno about Lancers, but FTO's have 2 ECUs as Aza says. The engine ECU is up in the drivers footwell, the tranny ECU is there behind the centre console.
Thats definitely the Auto Trans ECU. They are the only blue plugs in the loom.
    d_dan
    Post by d_dan »
    the ones in your engine bay are standard as far as I know
    the last one is atmospheric sensor and can be used to obtain rpm signal, first one ecu loom for auto by the looks and 2nd no idea sorry :?
    Vipfto, the last pic had 3 plugs though. Are they used for something?
    The first one yes I went through the electrical diagram and it is auto ECU. Do all FTO's have those wires or was the wiring loom from an auto in my car?
    sorry brown is atmo sensor
    blue is rpm signal
    not sure for other also
    and I would be sure yours used to be an auto at some stage too, When I converted mine did same and left auto loom in there
    If the white wire is going to the stepper then obviously the old harness was damaged and is a bad repair job. That other thing with the red hose connected to it looks like an aftermarket fuel pressure regulator?
    Storm
    Post by Storm »
    vipfto wrote:sorry brown is atmo sensor
    blue is rpm signal
    The last wire is the remote wire for the fuel pump so you can pressurise the system after doing any work in the engine bay. Connect it to a live feed and it will run the pump.
    The car is a Lancer converted to 6A12 MIVEC, so the loom may have been from an auto (car is manual).
    The wire doesn't go to the stepper motor. The stepper motor has a little thing that "holds" the wire. I am sure you've seen this before, it is a weak piece of metal that you bend to hold cables etc.
    The red hose is yes an aftermarket FPR I put in with my RPW extractors.
    So, basically nothing is "missing" from my car? ie, everything is as it should be?
    TCL
    spetz wrote:The car is a Lancer converted to 6A12 MIVEC, so the loom may have been from an auto (car is manual).
    Where's the white wire going to then? Looks like it's connected to the stepper harness.
    Bennoz wrote:Dunno about Lancers, but FTO's have 2 ECUs as Aza says. The engine ECU is up in the drivers footwell, the tranny ECU is there behind the centre console.
    Passenger footwell??
    TCL
