Brakes
smorison
The Godfather
Post by smorison »
RallyMad wrote:
I am going to buy my first FTO next year after I finish uni and get a job (I want a GPvR). So will the standard disks take upgraded pads like Racebrakes without warping or has everyone needed to update their disks as well. And also I'm going to want to be doing track days and stuff with my car so a brake upgrade is something at the top of my shoping list, hehehe. Anyway, I was just wondering what everyone with larger front disks have done with the rears. Have people put the larger stock fronts on the rear or jsut left them standard? Let me know what you've all done please.
Thanks in advance.
i haven't had any issues with rotor's warping, the stock ones however are wearing out a bit from the harder compounds of the RB74 pads
YYgirl
Post by YYgirl »
are these our rear or front pads ----> Bendix Pads - DB1249BS
TheSentry
Post by TheSentry »
YYgirl, that is the part # for the fronts, but that's only for FTOs with smaller front calipers. I believe that applies to the GS and maybe the GR & GX. Not sure about the last 2.
YYgirl
Post by YYgirl »
does 'dust' mean squealing? or what does it mean? thanks!
TheSentry
Post by TheSentry »
No, dust is just that, dust. Some brake pads create a large amount of dust which usually gets deposited around the brakes and on those precious rims. :lol:
Usually just a fine dark looking dust that comes off the pads.
Mitsiman
Approved FTO Australia Trader
Post by Mitsiman »
I have used DBA rotors and where I am using Bendix or equivelent pads they work fine and are good for teh average road user. To go any harder requries use of more metallic pads with the dba rotors which creates warpage and high wear pattern.
The alternave is that we have personally foudn and stick with is teh EBC range of pads and brake rotors. I can garauntee since we have gone to this package, we have never had a warpage problem or cracking, we have superior brakes both cold and hot, reduced brake fade.
I have a custoemr with a Mitsubishi Magna running ralliart brakes and he was crackign and wearing otu a complete set of rotors and pads in once race. We upgraded him to our package of rotors and pads and since then third race on the same rotors and replacing one set of yellow EBC pads per meet (Example of how hard he is braking).
The point being I personally feel EBC pads are one of the best out there.
Some prices for those interested - note prices are for slotted rotors but not cross drilled which we do not use or recomend.
Front Rotors $176.00 Per rotor incl GST
Rear Rotors $160.00 Per rotor incl GST
EBC Kevlar Green Stuff front brake pads $260.00 incl GST
EBC Kevlar Black Stuff rear brake pads $125.00 incl GST.
I run this same package (but larger rotors on my magna) and cannot reocmend it enough.
All these items we stock and can ship out COD australia post if itnerested.
G1
Post by G1 »
Hey guys what's the part number for the front RB74 pads for the GPX/GPVR?
D-TRAIN
Post by D-TRAIN »
The full part number is DB1223-RB074. That's what I got on the receipt.
G1
Post by G1 »
thanks dave, did you get the rotors as well?
how do you find them?
D-TRAIN
Post by D-TRAIN »
G1 wrote:thanks dave, did you get the rotors as well?
I only had the Mitsubishi OEM ones to compare it with and they were pretty worn. So the stopping power was pretty obvious when I first had them fitted. The only complain is brake dust. About every 800kms my front alloys get pretty gritty. Other than that no complains.
When I was at Race brakes, I got them to check my rotors. All the discs were fine, no sign of warpage, or the need to machine them.
Get your current ones checked first if you are thinking of getting rotors.
d_stroy_r
Post by d_stroy_r »
while we are on the subject of brakes, i have these called WINMAX.
Never heard heard of them but i deffinetely reccomend them if u ever find any. They stop so easily without causing a fuss.
Has anyone else heard of this brand?
GPXXX
Post by GPXXX »
d_stroy_r wrote:while we are on the subject of brakes, i have these called WINMAX.
Yep, they're from Japan and they're used quite frequently in production car races. My car came with a worn Winmax sticker when I picked it up so who knows maybe I might have had Winmax pads fitted at some stage, LOL...
elmo
brakes
Post by elmo »
just got my stoppers redone(due to damage from being stolen) and upgraded to slotted all round. Stops like a dream, better than ever, the package mitsiman reccomended earlier in this post ( he was fitting that to my car) its sh*t hot!!
Jeff
Post by Jeff »
Does anybody have the part numbers for the DBA slotted rotors and Greenstuff pads for a GR.
Previously someone posted part numbers but they were for the GPX.
Thanks
Jeff
