Air filter
Air filter
what is the best air filter to use? what type or brand is best suited for a FTO
- phi-tec
Re: Air filter
umm try a search pretty sure theres a hardcore thread somewhere with very detailed explanations in the end restriction is money!MikeFTO wrote:what is the best air filter to use? what type or brand is best suited for a FTO
- Chiinkstarrh
Re: Air filter
k&n
Re: Air filter
Fto's have an internal filter system inside the intake manifold, there is no actual need for an airfilter, it has been shown to have around 10kw gain on running no secondary filter aka air filter located inside the stock box.
- Dras
- bass_twitch
Re: Air filter
ACCCTUALLY Matt, ive seen dyno sheets that proves its from 9-13kw gain, but thats after you remove the pipe from the airbox to the tb so more air can get into the tb without having to go through a long maze of pipessilverGPX wrote:Fto's have an internal filter system inside the intake manifold, there is no actual need for an airfilter, it has been shown to have around 10kw gain on running no secondary filter aka air filter located inside the stock box.
- aza013
- NSW Coordinator
Re: Air filter
.Taz wrote:ACCCTUALLY Matt, ive seen dyno sheets that proves its from 9-13kw gain, but thats after you remove the pipe from the airbox to the tb so more air can get into the tb without having to go through a long maze of pipessilverGPX wrote:Fto's have an internal filter system inside the intake manifold, there is no actual need for an airfilter, it has been shown to have around 10kw gain on running no secondary filter aka air filter located inside the stock box.
Re: Air filter
On both fronts
- mosti
Re: Air filter
http://www.ebay.com.au/itm/DUAL-Superch ... 3cb0869fbe
I purchased one of these....
100km extra tank of fuel and 30kW more on the dyno!
- phi-tec
Re: Air filter
LOLmosti wrote:http://www.ebay.com.au/itm/DUAL-Superch ... 3cb0869fbe
and did taz just say what matt did ?:S
- Eltnot
Re: Air filter
Call me a skeptic, but I'd rather keep my filter attached than believe this internal filter stuff. If there is an internal filter, how do you change out the filtration material? Crud has to get stopped somewhere to be a filter which means it must be cleaned/replaced.
- bass_twitch
Air filter
Eltnot wrote:Call me a skeptic, but I'd rather keep my filter attached than believe this internal filter stuff. If there is an internal filter, how do you change out the filtration material? Crud has to get stopped somewhere to be a filter which means it must be cleaned/replaced.
- Gholdwayne
Re: Air filter
^bass_twitch wrote:Eltnot wrote:Call me a skeptic, but I'd rather keep my filter attached than believe this internal filter stuff. If there is an internal filter, how do you change out the filtration material? Crud has to get stopped somewhere to be a filter which means it must be cleaned/replaced.
97 GPX Icelle Blue
I cant stop driving her!
FTO[For The Orgasm]
FTO[For The Orgasm]
Air filter
Someone is a serious Sally
Re: Air filter
With pods, more exposure to the outside element, the better(front bar set up). Heat soak is one of pods downside.
Shielding from water puddle and the police is to take into consideration.
My 2 cent.
Hehehe.
My 2 cent.
Hehehe.
Re: Air filter
Dude but it doesnt matter, its already got an internal filter, ive seen so many ftos running no intake pipe and there getting great gains.BearOnFire wrote:With pods, more exposure to the outside element, the better(front bar set up). Heat soak is one of pods downside.
My 2 cent.
Hehehe.
Haa just cbf taking mine off im just too busy, reccommended for anyone i reckon.
Re: Air filter
Yeah? I'm currently using panty hose for the last 3 days, the look you get at the check out must be taken into consideration.
Godzilla got nothing on me!
- Shane001
Re: Air filter
For anyone out there not familiar with the idiots posting above THERE IS NO INTERNAL AIR FILTER ON THE FTO. DO NOT REMOVE YOUR AIR FILTER. AND DON'T LISTEN TO THESE MORONS
Seriously someone will read these posts and believe you and end up with a fucked engine which you lot will think is real funny but which is not going to reflect well on the club now is it
