Project Rejuvinate
Re: Project Rejuvinate
Are the covers painted? As they look great.
Dras
Post by Dras »
Yup, the rocker covers are painted. Quite a nice colour too if you ask me.
Dras
Post by Dras »
Reconditioned steering rack thanks to Mr. Racks.
Timing belt, reconditioned fuel injectors, oil filter and fuel filter.
hey buddy how much did it cost to get the rack reconditioned? and did u rip it out yourself?
Dras
Post by Dras »
$320 and it came with a 3 year warranty.
That price didn't include removal / fitting but they do provide that as a service if you require it.
They showed me their test bed, quite impressive. They test each rack to withstand 1000psi!
ok I found the little buggers :lol:
they are a bit on the drity side but hay what can you do :roll:
I should add that these have done around 80K, some of that track.
Dras
Post by Dras »
Thanks for that Aza, so the markings on mine indicate that they are oem, hmmm.
Dras wrote:Thanks for that Aza, so the markings on mine indicate that they are oem, hmmm.
yep you would be right there. Did they say that they would put after market ones in or just do a freshen up on them (new rings.......)?
it looks from your pics that they just chucked them back in. They could have steam cleaned them first.
FTO-BOY
Project Rejuvinate
Post by FTO-BOY »
How much was the engine reco and where at?
Dras
Post by Dras »
They said that they would replace the pistons (not necessarily with aftermarket ones). In heinsight, I should have asked for the old ones back to ensure they used a different set.
FTO-BOY wrote:How much was the engine reco and where at?
It cost $4500 to get it reconditioned including having the 6 fuel injectors done, engine balancing, up-ing the compression and it includes a 3 year, 100,000km warranty. It also included pick up and delivery of my engine from my garage.
The price did not include a new oil pump (old one was within spec so it was reused), water pump or idlers / tensioners, which I will be fitting new ones of.
This is more than they initially quoted me by about $500 but I didn't want to argue with them and risk them cutting corners. The work was done at ARA Engine Reconditioning in Guildford.
FTO-BOY
Project Rejuvinate
Post by FTO-BOY »
Ok cheers for that. Thinking of getting my MIVEC motor done rather than buying a new one. So far done 260,xxx km and pretty slugging. Why did you need new pistons?
Dras
Post by Dras »
FTO-BOY wrote:Ok cheers for that. Thinking of getting my MIVEC motor done rather than buying a new one. So far done 260,xxx km and pretty slugging. Why did you need new pistons?
I don't know if I needed new pistons, but it is one of the items I was charged for. I just want to make sure that if I pay for it, I get it.
FTO-BOY
Project Rejuvinate
Post by FTO-BOY »
Ok right! I might give em a call and ask for a quote and inquire whether the pistons requires to be changed :-)
mattman
Post by mattman »
being a Cylinder Head Machinist id say the bore's on the block and pistons were still with in spec so they would have given the block a light hone and fitted new rings if there were new pistons you would be able to tell and most of the time they use aftermarket replacement pistons but in this case it looks like factory pistons and thay look dirty :?
if this was me handing over that much cash id be asking questions
FTO ftw
Dras
Post by Dras »
mattman wrote:being a Cylinder Head Machinist id say the bore's on the block and pistons were still with in spec so they would have given the block a light hone and fitted new rings if there were new pistons you would be able to tell and most of the time they use aftermarket replacement pistons but in this case it looks like factory pistons and thay look dirty :?
I would love to, but without anything concrete I don't want to start accusing them of anything.
FTO-BOY
Project Rejuvinate
Post by FTO-BOY »
Dras have you got their number? I want to get a quote (without replacing the pistons)
Dras
Post by Dras »
FTO-BOY wrote:Dras have you got their number? I want to get a quote (without replacing the pistons)
http://www.araenginereconditioning.com.au/
nice work mate,
meticulous as always...
wondering how your letting this much moolah slip past the mrs?:D
Dras
Post by Dras »
SchumieFan wrote:nice work mate,
Thanks!
Well, I was looking at getting a second hand BMW 135i, but they start at around the 50k mark. From there it wasn't a hard sell to spend a 10th of that on fixing my car.
If all goes well, the motor goes in next weekend.
Can't wait to see pics of it in, its going to look immaculate, good work mate!
