my v6 mivec colt going awd turbo :)
Re: my v6 mivec colt going awd turbo :)
not to sure what he says about it but he did say is wasnt reving as much as it should.
not sure if it was a wire or the rev counter was causing a fault in the rev range.
it was still reading for 4 cyl on the dials
- payaya
The rubber part of your left and right engine mount.gavo's mivec wrote:whats a side mount insulator?
nope just standard glass then had them tinted
nah im sure thats the way the top mounts sit man
for some reason they couldnt read the exact rpm
the purple colt seems more controlable
not sure if its because im using d2 coilovers
i was using jic coilovers in the black colt
they were both around the same millage
there is only 3 days of manufacturer dates with them lol
yup will keep yous posted
ahh right lol
yea they are the same
- payaya
Cool thanks mate. Is the stiffness of the mounts similar?
nah id say they are the same tbh mate
Ok mate just went a run in the v6 colt. I have accurate dials now and it does seem that it hits the limiter just under 7k rpm :-Sspetz wrote: 3. On your dyno sheet, you seem to be making peak power really early? Under 7,000rpm
Keep up the great work, and make sure to keep updating us
What can I do about this?
- spency
I hope you're not taking that reading from a cold engine. Try driving around for 20-25 minutes to allow the engine and gearbox oil to FULLY heat up, then give it a squirt. Did you change your oil when you put in the engine? Does it have a FTO ecu?
Yeaa it was more like a hour and yea the oi and ecu were changed.
Mivec is coming in fibe aswell just really confused as to why it limits just under 7000rpm
- spetz
What rpm does MIVEC come in at?
Ok it seems to have fixed itself
Fech knows what was up with it
A wee update, my wife blew the fiat punto up abd had to use the spare colt, so I had to put my v6 back on the road as a n/a
But with the mivec controller on and the rev counter working properly I went on the dyno, running a tad rich but managed 211bhp
141whp
Pretty happy with that result,
Also managed 115bhp and 81whp
With my 1.6 sohc colt
141whp
- Kustom
Any updates buddy?
- fto-007
Hi just wondering what car did you use the awd out of and gear box did you use? do you use a evo 3 drive train and trailing arms with a vr4 gallant gear box? did you have to use the floor pan out of an evo 3 to get it to work? very interested great work by the way a lot of hard work and time put into your build keep it up
