ok so i have the rspec mivec controller and it was a plug and play harness
the only issue i have is that when i turn the car off then on again it resets its self. and the second issue is that it is reading for a 4 cylender car so the revs are showing higher than they are.
i printed of the info sheet on the controller telling you all the functions but it doesnt seem to change onto the cylender settings.
i can get it to go to the clock,alarm mivec points, rpm limit, stopwatch. anyone any ideas
cheers guys
gavo
r spec mivec controller issue ( need a little help)
Re: r spec mivec controller issue ( need a little help)
It's a pain to set, I used to have one.
Mine used to reset if the battery was off but not just after turning the power off.
Some instructions here: http://www.mitsubishi-fto.org/parts/ele ... mvc85x.htm
yea thats the instructions i have but when i hold the top left (function button) nothing happens
how did you change it to read 6 cyl?
FIXED
Ok if this ever happens to anyone what to do is press loads of buttons rapidly and at some point the option is there haha
Yeah that's how you do it lolgavo's mivec wrote:FIXED
- aza013
- NSW Coordinator
Pushing all the buttons like that I wonder what other things you have changed in doing so.
Lol dont worry. Once it was on the bit I wanted I went and set everything up
Working fine now woop woop
