best piggy back system?
- Connor_1994
any suggestions on what the best piggy seystem is to get?
Re: best piggy back system?
dude. honestly. are you serious?
- Connor_1994
damn computer, system*
am i serious about what?
getting one, or which one is best?
- vipfto
For Australia has to Haltech seems to be common for most tuners to be familiar with
- Connor_1994
well haltech it shall be then,
i looked earlier but couldnt find one for an fto, so, was looking around and thinking apexi
- spetz
I would recommend an e-manage. I've read people saying they are better
- aza013
- NSW Coordinator
It comes down to what you want it to do and what mods you have on the car.
There's f**k all support for emanage out here.
- vipfto
^ This
maybe it is better but like I said most tuners are Haltech friendly
- BUZZ_QWERTY
Should just ask the place you are planning to get the tune done what they are familiar withConnor_1994 wrote:any suggestions on what the best piggy seystem is to get?
- Shane001
Haltech is definitely the simplest option, only a few wires to splice in and yes much simpler to 'tune'. So it goes without saying that there is more dyno tuner support for it
eManage Ultimate can do a lot more, but is a lot more complicated and yes not many people around who know how to install or tune them, but then again there's not many people around who know how to tune period
If you want simple and low cost stick with the Haltech. If you're up for a challenge and can learn how to do a lot of it yourself go the eManage Ultimate.
Or better yet Jonowong is selling an emanage blue WITH both harnesses for 350 - bargain price so theres your answer, and im sure someone within your city will be familiar with them, not like they are some back alley brand no one has heard of
- spetz
Do you know why this is?Bennoz wrote:There's f**k all support for emanage out here.
It seems like such a popular and powerful piggyback system
- vipfto
Because most Australians are pretty dumb and cant work them outspetz wrote:Do you know why this is?Bennoz wrote:There's f**k all support for emanage out here.
- Shane001
Correctedvipfto wrote:Because most Australians tuners are pretty dumb and cant work them outspetz wrote:Do you know why this is?Bennoz wrote:There's f**k all support for emanage out here.
RPW support the emanage blue, although they're a bit far away from you.
I quite like the emb, find it simple to get a basic tune myself for fuelling and then let the tuner fine tune the fuelling and ignition timing, I used to run a couple of degrees advance at certain points and that was with boost, I didn't touch the timing myself though left that to the experts.
But i've heard good things about the Haltech and there does seem to be a lot of support here for it and people getting good results too.
