4L Valvoline Duragear 75w-85 GL-4 = $39 @ Repco till 16th/9
- phunkydude
As per title.
For FTO manual gear oil.
Re: 4L Valvoline Duragear 75w-85 GL-4 = $39 @ Repco till 16t
+ NRMA member discount
- ZFL45H1
This is good oil I assume
Its what I use. It has the Bennoz seal of approval.
*Insert cheesy pick of me smiling, thumb up with a tick of approval*
- ZFL45H1
Well ill be getting some the due for a change along with engine oil
- crosso
What's this? I get discounts?Bennoz wrote:+ NRMA member discount
- phunkydude
Bennoz wrote:Its what I use. It has the Bennoz seal of approval.
just paid 60 not so long ago for 5litres of the same stuff but penrite - matt wanted the swaree fully synth sh*t so i ended up with a few spare bottles.
- vanadinite
Is this oil ideal for a 5speed manual with viscous LSD? or do you recommend something different?
It's fine for that.vanadinite wrote:Is this oil ideal for a 5speed manual with viscous LSD? or do you recommend something different?
The viscous section of your LSD is sealed & uses it own supply of lubricant.
- vanadinite
[/quote] It's fine for that.
The viscous section of your LSD is sealed & uses it own supply of lubricant.[/quote]
Ok great, just making sure.
