damn car wont start....
ANBU_fto
Post by ANBU_fto »
guys help me.... :? :cry:
my fto wont start.... it was fine like when i was driving it, but then when i took the key out of the engine the car wont start again.... even when i turn the key... i hear no noises at all... nothing.... :cry: :cry: i checked the fuses and none of them are blown.... omg i dont know what to do.... someone help!!!!!
TimmyD
Post by TimmyD »
im no expert but it sounds as though your starter motor may have givin way..
ANBU_fto
Post by ANBU_fto »
what do u mean by that???? :( :( :( :( :( :( :(
TimmyD
Post by TimmyD »
http://www.thepartsbin.com/automobile-starter-motor.html wrote:When to Replace Your Automobile Starter Motor
If you try to start your vehicle and the engine turns too slowly, or not at all, the starter or starter solenoid may need to be replaced. Before you go through the steps of replacing parts always do a few troubleshooting techniques to make sure that the starter or the solenoid is the problem. Because the starter and the solenoid work together its always best to replace them together.
Starter Motor Troubleshooting Tips:
Check the battery cables and terminals for corrosion.
Clean the corrosion and replace the battery or cables if needed.
Check the wires to the starter and the solenoid for cracks, corrosion, or breakage.
Make sure your battery is charged enough to perform starting functions. Note: your instrument lights and dome lights may come on but your battery may still not have enough power to start the car.
Remember electrical parts fail mostly in part to time and usage not because of wear and tear like mechanical parts. And the damage is mostly in the internal electrical wiring, so some failures cannot be noticed from an outside inspection. If you have done the tests listed above and are still having problems starting your vehicle, then here are the steps to follow for proper installation of your automobile's starter motor.
more info here:
http://www.thepartsbin.com/automobile-s ... motor.html
thecook
Post by thecook »
when my car didnt start is was because my battery was dead, and i had no petrol lol
Slither
Post by Slither »
If u can't hear anything when u turn the key then it sounds like your battery is dead, if u put your key to accessory settin does the radio or climate control come on?? If not then its most likely your battery, if they do then its possibly your starter motor like TimmyD said
ANBU_fto
Post by ANBU_fto »
no, no lights like that at all, no climate control ligts or the radio thing...
so it could be the battery?
my alarm isnt even working... i cant lock me doors... :(
Black_FTOGPX
Post by Black_FTOGPX »
Had this a while back, it was because my mate left the interior lights on all night and the batt went flat.
Charge the batt and make sure the battery cables are nice and secure.
See what happens then. :D
smorison
The Godfather
Post by smorison »
Black_FTOGPX wrote:Had this a while back, it was because my mate left the interior lights on all night and the batt went flat.
don't suppose your car alarm went off when you tried to start your car ;)
if that's the case then your battery is definately dead
ANBU_fto
Post by ANBU_fto »
the little red flashing light for the alram or something doesnt even flash no more... i can turn on my head lights and stuff.... but no other lights... i cant even work the central locking...
i even tried to jump start the car.... but only left it for like less than 10 mins.... and still no noise came fromt he engine at all....
would anyone know where the kill switch is btw???
Black_FTOGPX
Try any another battery
FTO338
Post by FTO338 »
ANBU_fto wrote: my alarm isnt even working... i cant lock me doors... :(
You can always just use your keys. :wink:
Slither
Post by Slither »
I'd just replace the battery all 2getha rather than tryin to jump start the car, but it seems strange as your headlights will turn on???? Is that while engine is running, or not? if it isnt then it seems strange that your headlights will work but nothin else, well that is unless u blew a hell of a lot of fuses all at once :wink:
Just change the battery and c how u go
ANBU_fto
Post by ANBU_fto »
yea i think ill try that....
i thought i blew a fuse or something but, when i took a look at the fuses... they all were working fine.... i dont know whats wrong with the car....
ANBU_fto
Post by ANBU_fto »
guys thanks for the input but i found out what is was....
it was something the viet guy called the starter control box....
kekeke i replaced it with another and now the MIVEC roars once agian....
thanks again guys
:D :D :D :D :D :D :D
starter control box?? Never heard of it?
Starter Motor maybe?
hnm738
Post by hnm738 »
what is a starter control box???...anyone?
i doubt there is such thing?
