FS: 4 x Adjustable Cam Gears
- Valandis91
Since I never had the chance to put them on mine I'm selling these at a massive loss to myself. I paid close to $900 for these. As new!
Made by Envy Dyno so you can be assured it is a quality make and you can tell from the final product. Andodized blue as you can see in the picture. Perfect for making tuning changes to a NA or turbo FTO. Comes with sensor plate for GPX and GR so suitable for all models...
Like I said as new and asking $500 including postage...
Sent from my HTC Velocity 4G using Tapatalk 2
- ZFL45H1
Re: FS: 4 x Adjustable Cam Gears
hmmm ill most likely take these if there still around when my pay comes in!
actually ill pass ill but just buy some down the track when i eventually buy some after market cams. anyway good luck with the sale buddy
- Valandis91
- ZFL45H1
Did this end up fitting in the crank angle sensor properly
- Valandis91
The issue was that they were originally gr gears so they had a slightly different sensor on them. So when the gpx sensor was put on it was slightly out of time. I figured this out. My retarded mechanics didn't know. But it was too late by then.
How difficult would these be to set up and adjust? What sort of gains can you get out of them?
- ZFL45H1
Ok so in saying that would it fit now on a mivecValandis91 wrote:The issue was that they were originally gr gears so they had a slightly different sensor on them. So when the gpx sensor was put on it was slightly out of time. I figured this out. My retarded mechanics didn't know. But it was too late by then.
ZFL45H1 wrote:Ok so in saying that would it fit now on a mivec
Valandis91 wrote:Comes with sensor plate for GPX and GR so suitable for all models...
- ZFL45H1
But before said he had troubles just a double checkDaniel2019 wrote:ZFL45H1 wrote:Ok so in saying that would it fit now on a mivecValandis91 wrote:Comes with sensor plate for GPX and GR so suitable for all models...
Good pointZFL45H1 wrote:But before said he had troubles just a double check
- Valandis91
Yes they would fit into a mivec, the gears are fine apart from the one with the sensor plate attached. This would need to be realigned ever so slightly but if you have your original cam gears then this would be very easy and any mechanic with half a brain could fix it easily
- Lawso
- Penis Fingers
- aza013
- NSW Coordinator
You called?Lawso wrote:aza?
Not for me sorry, I'm still working out what way I am going to go with my car . But it's a good mod for some one doing a big upgrade.
- Lawso
- Penis Fingers
sorry mate, i thought you were looking at something similar about a year or so ago
- ZFL45H1
Exactly times change hahahaLawso wrote:sorry mate, i thought you were looking at something similar about a year or so ago
- vipfto
Thinking bout them BTW can I have my old cam gears I loaned you back when these were fabbed?
