Car Wreck
Re: Car Wreck
You could ask the wreckers to remove the airbag for you if you realy wanted it :idea:
Re: Car Wreck
You will need to mod the horn to work as well.
The Momo wheel has a different setup than the stock GPX with no bag
Lawso
Penis Fingers
Re: Car Wreck
Post by Lawso »
i'll take the head unit!
and the headlights!
Re: Car Wreck
If you had an airbag explode into your face when your up against the steering wheel, theres a good chance thats the end of you
Much more dangerous than they look (or so the stories ive heard tell me)
Ive removed the airbag wheel a number of times before. Firstly, not all of them have the airbag inside as it was also sold as just an upgrade (in which case the airbag will be missing). I just made sure that the battery was disconnected for some time before hand and then didnt let my face get anywhere near the wheel when taking it apart. You will need the right size star shaped allen key though as there are special screws holding in the centre section of the wheel.
If you do decide to try it, keep your face well away from the wheel when you are working on it though.
    fraz91
    Hair-do
    Re: Car Wreck
    Post by fraz91 »
    Dstocks is right. You need to disconnect the battery and leave it disconnected for a good 10-15mins to get rid of the residual charge, Subaru recommend 30mins before touching it. 8O
