Good Audio for ~300$ ? (already own headunit)
Hi,
I just got my Black 1994 GPX FTO !
The speakers with the car are the originals (which are, total crap!) But the head unit is a Sony with 52Wx4
Was thinking of getting Pioneer (I used to have pioneer a long time ago, bloody brilliant!) 6x9 in the back and to change the ones in the front, BUT...
I don't have a shed/garage nor the tools to do custom backboard for the speakers, So either I need speakers which fit in the original settings (which I think is hard to get)
or if you would recommend a decent shop around Melbourne (Clayton) that would be great too.
Re: Good Audio for ~300$ ? (already own headunit)
Fronts are 6.5 from memory.
Rears are standard 6x9.
And WTTC!
And WTTC!
What's WTTC ??
And are there specific speaker models that you recommend ?
Oh ! And where can I find the cheapest !!!
WTTC = Welcome to the club
Kickers have had very good reviews, although get the higher models, not the bottom ones.
You can also pick up Alpine Type S gear cheap from the US I believe.
- mattman
welcome buddy every one has there own taste in brands but i do have a set of alpine type s 6x9s in my fto and for general duties there not to bad.Daniel2019 wrote:WTTC = Welcome to the club
FTO ftw
WTTC
I have these and they are awesome
I am running amp'd power to them though
I found Ryda to be cheap....
http://www.ryda.com.au/Kicker-KS693-6x9 ... /ks693.htm
http://www.ryda.com.au/Kicker-KS6-2-6-K ... p/ks62.htm
JB HIFI could be cheaper if you wait for a sale....(I was in there last sunday and they had 30% off all car sound)
http://www.jbhifionline.com.au/car-soun ... ers/666105
http://www.jbhifionline.com.au/car-soun ... ers/668358
These look awesome !WTTC
thanks for the help guys! I'll check out JB HiFi this weekend and see if the sale is still on.
These install without any special tools? Do I need the "L" screwdriver ?
- Akys
- Manual Conversion
Yes, the "L" screwdriver will make changing the 6x9 a lot more easier.prof_hussam wrote:These look awesome !WTTC
I just use a screw bit from a drill and a shifter or those grip things
I just use one of these with a phillips head attachment - work wonders and can probably walk into any auto shop and get one cheap
http://www.ebay.com.au/itm/4-pc-Flexibl ... 435wt_1139
- Kustom
What do you need the "L" screw driver for? I can't remember needing it for my FTO audio install.
Cheers
Cheers
To remove the parcel tray - the screws at the back which hold it down - cant really get anything in there as the rear windscreen gets in the way of a screwdriver
Parcel tray doesn't have any screws at the back. Just at the front. The L shaped screwdriver is needed to remove the back screws of the 6x9 speakers.
Mine does right in the back corners as well as the speakers
- Supplanter
Some parcel shelves were replaced with custom baby-chair-anchor jobbies, because for some compliancers it was easier than fitting them to the factory shelf. Mine was replaced with a fabric covered piece of MDF.
I got rid of the screws for the 6x9's, drilled the holes a little bigger in the parcel shelf (from the boot side being careful not to let the drill bit touch the rear window) and used small nuts/bolts to anchor the speakers.
The heads of the bolts hold themselves still against the outer metal edge of the speakers, so I can remove the speakers with a socket via the boot.
I found the 6" speakers slightly smaller then the plastic mount in the doors but I managed to get 3 out of 4 screws in.
- ObsidianRadio
Hey mate!
For $100, you can get yourself a set of Clarion 6" splits, and put the tweeters in your dash... Sounds absolutely awesome and they have lasted me almost a year now with no fault!
6X9s vary as do subs, but that's just my two cents
