brembo brake kits
Private Sales Only
Ephercius
brembo brake kits
Post by Ephercius »
Anyone know where i can buy brembo drake kits maybe have a look at the prices as well
Re: brembo brake kits
Look at Bennoz' thread in turbo FTO, he has evo 5 brembos on his car.
Or you can get Mitsubishi GTO brakes and kit from Freaky Parts in the UK.
He also may do Brembo kits also..
You'd need to source them from an Evo.
You need the hub/knuckle, front lower control arm and the actual brakes. Good idea to use an Evo brake master cylinder too.
It's been done a few times before. Try googling brembo brake conversion for Colt, Mirage and FTO, as the parts are all the same
Wilwood also does a "big brake kit" upgrade for the FTO I'm fairly sure.
Daniel2019 wrote:Wilwood also does a "big brake kit" upgrade for the FTO I'm fairly sure.
Wilwood don't make a direct kit for the FTO. However there are a couple of online stores in the UK that do Wilwood kits.
The calipers and rotors are Wilwood, but the brackets and rotor hats (if two piece rotors) are not Wilwood.
They do look pretty good value though, assuming the brackets and hats are well made.
