(Although there is no stutter while driving, I can sometimes see the rpm needle take a quick dip while idling.) Just wanted to make sure if the coils are ok anyways.
So according to my engine's manual, and Bennoz's link (http://www.ehow.com/how_4912368_check-c ... meter.html) this is what I am doing:
Engine Manual:
![Image](http://i.imgur.com/6WuS2.jpg)
The Coil in question:
![Image](http://i.imgur.com/9BWWM.jpg)
To get the primary resistance of the coil am touching the middle pin and the 3rd pin in the plug A as named in the diagram. (Reads .578 k ohms)
To get the secondary resistance of the coil am touching the Spark Lead connector C and the Spark Plug connector B metals. (Reads 10.3 k ohms)
(Both measurements are taken on an autorange meter)
Am I doing it the right way?
So according to the manual my primary resistance should be between .7-.86 ohms and secondary resistance should be between 11.3-15.3 k ohms. My readings are lesser than that, therefore my coil is bad?
This is my first time with a multimeter and learning things..so sorry for the noob question
