vipfto's turbo ride
- vipfto
vipfto's turbo ride
Well figured should put up some pics and details in here
Exterior:
- Bozz speed front bar, Gpvr wing, veilside side skirts
-18x8 rims shod with Yokohama AD08 semi's 225/40R18
-Evo 3 brakes slotted (same as GPX) with EBC red stuff all round
-clear side repeaters
-Hid's
Interior:
Recaro seats with purpose rails
DVD GPS head unit etc
8 speaker system (front splits, 6x9's and couple other tweeters in roof lining) JBL Sub all run off two amps
Carbon style dash EL (White ones in post now)
Stainless dash rings cups and shroud
Oil pressure and boost gauge in centre pods
Performance mods:
larger throttle body and machined plenum to match
2.5" mandrel mild steel exhaust from turbo through 'de-cat and high flow for street' 1x resonator and muffler
275cc injectors and walbro pump 255 to match with all new braided lines from tank to rail
all air con components removed
manual conversion HD clutch and lightweight flywheel braided clutch line
Custom up and down pipe
TD05 turbo with front mount intercooler
BOV
all new braided oil feed/return and water lines for turbo
HKS pod filter
Fuel pressure regulator adjustable
Greddy Emanage blue ECU
Boost controler
coilovers
front and rear upper strut brace and lower front brace
larger rear swaybar
all poly bushes throughout with extra castor front control arms
battery in boot
158KW ATW street tune
and many other little custom things that I cant remember right now
have couple other bits to put back on will post pics when get round to doing them too
Exterior:
-Hid's
Interior:
Performance mods:
BOV
HKS pod filter
Boost controler
coilovers
larger rear swaybar
battery in boot
- bjk
- Totes
- spetz
Re: vipfto's turbo ride
Looks really good, must be lots of fun to drive.
How much boost are you running?
- vipfto
9psi but going to drop it to 7 just waiting for new actuator spring
- Kustom
Hell yeah! Good job with all of it
- kiz
- SA Coordinator
Confused as to what I was beaten to?bjk wrote:Shotgun! Beaten by Kiz I suppose.
But looking good Tim. Gotta go for another spin when it's complete
1998 Mitsubishi FTO GPVR AERO
- aza013
- NSW Coordinator
f**king love the look of it .
You now just have to bring it up to dstocks bonfire weekend so I can do them lights for you .
- bjk
- Totes
Getting a ride in the car, haha.kiz wrote:Confused as to what I was beaten to?bjk wrote:Shotgun! Beaten by Kiz I suppose.
Looks soo damn good!
- crosso
Thats beautiful man, looks amazing. Would love to see how it drives
- vipfto
All good just need to polish them kinda been slack on cleaning latelyaza013 wrote:f**king love the look of it .
- ObsidianRadio
Looks great man, probably the cleanest I've seen it thus far
Spin is in order on the asap!
- vipfto
put couple shiney bits back on and started the long process of re-polishing and cleaning engine bay before starting the outside.
- aza013
- NSW Coordinator
Looking good .
- bass_twitch
GL ever selling to a P plater now! "cop is that a turbo", "Nope!"vipfto wrote:put couple shiney bits back on and started the long process of re-polishing and cleaning engine bay before starting the outside.
"But it says so in big blue letters"
On topic though,
looking awesome mate!
- vipfto
Haha yeah no turbo here officer it's just for looks lol
Will never sell it though had almost 8 years now actually hardly drive it use motorbike most of time except when I lose keys like I have for last week hahaha
what spark plug leads are you using?
these? http://www.ebay.com.au/itm/130834400515 ... 1423.l2649
- vipfto
- kiz
- SA Coordinator
adzski wrote:what spark plug leads are you using?
Haha clearly didn't look at the linkvipfto wrote:Na magnacor ones.
