BJK's '95 GPX
- rock_it
Re: BJK's '95 GPX
Don't mix oils.
Yes put through oil cap or as some people call it the 710
Fill until dipstick says so.. I think just over 4L to full..
- ZFL45H1
Re: BJK's '95 GPX
Yes put oil in where it says oil on the cap and just keep putting it in and checking the dip stick after putting some oil in stop when it hit the full markbjk wrote:Aaand oil is down. Must've still been warm when I looked at it last night. Is a little above the 3/4 mark. Looks like I'll be making a run to supercheap on Monday.
How do I know how much oil to put in? And on noob-assumption I'm guessing I put it in through the oil cap thing on the engine?
- bjk
- Totes
Re: BJK's '95 GPX
As in, don't mix weights? Like 10w40 with 15w40 or something like that? Would it be safe to assume there's 10w40 in there from the last service? So I'd be putting about 1L in?
- rock_it
Re: BJK's '95 GPX
Brands or weights..bjk wrote:As in, don't mix weights? Like 10w40 with 15w40 or something like that? Would it be safe to assume there's 10w40 in there from the last service? So I'd be putting about 1L in?
If you dont know what is in there, do a full drain and change..
- bjk
- Totes
Re: BJK's '95 GPX
Hm, okay. Might check with dstocks and see if the mechanic remembers (I should hope) what he put in so I don't drain out basically fresh oil.rock_it wrote:Brands or weights..bjk wrote:As in, don't mix weights? Like 10w40 with 15w40 or something like that? Would it be safe to assume there's 10w40 in there from the last service? So I'd be putting about 1L in?
Re: BJK's '95 GPX
Just top it up, lol you can mix oils, who gives a f**k? It's a 1995 model?
Just don't put a sh*tty mineral based in there and dont go above 15weight.
- bjk
- Totes
Re: BJK's '95 GPX
Don't say that, now I'm conflicted! But there's no harm chasing up what's in there.silverGPX wrote:Just top it up, lol you can mix oils, who gives a f**k? It's a 1995 model?
- ZFL45H1
Re: BJK's '95 GPX
Just get either a 10w 40 or 10w 30 in semi synthetic but no it won't matter if u chase up the oil that's in it but it also won't matter of u don't
- rock_it
Re: BJK's '95 GPX
Your car your choice. I have been advised by numerous mechanics and the message was clear..
Dont mix oils. So that is what I live by..
- kiz
- SA Coordinator
Re: BJK's '95 GPX
Same goes for alcohol as wellrock_it wrote:Dont mix oils. So that is what I live by..
1998 Mitsubishi FTO GPVR AERO
- vipfto
Re: BJK's '95 GPX
yip just drain and refill with new, for a cost of round $40 its worth it and you dont have to change filter every time only a 5 min job takes 4l if not changing filter in which case 4.3l
- kiz
- SA Coordinator
Re: BJK's '95 GPX
Are you sure about that? Let's not have an incident like we did with my gear box oilvipfto wrote:takes 4l if not changing filter in which case 4.3l
- vipfto
Re: BJK's '95 GPX
Yip only way to fill box oil is to when it starts to come out although its approx 2.6l
- aza013
- NSW Coordinator
Re: BJK's '95 GPX
Agreed. If it is not coming back out the filler hole then it is not full.vipfto wrote:Yip only way to fill box oil is to when it starts to come out although its approx 2.6l
- kiz
- SA Coordinator
Re: BJK's '95 GPX
I still think we spilt about half a litre on the floor haha
- bjk
- Totes
Re: BJK's '95 GPX
Mmk. So if I buy a 5L bottle I should be fine. When was our next DIY day?
- vipfto
Re: BJK's '95 GPX
Think sunday coming check sa section. Sure we can manage that too and yip 5l bottle great
Re: BJK's '95 GPX
I can somehow see this guy getting confused and filling his engine up to the filler hole.
Re: BJK's '95 GPX
Guess who done that? yep my ex done thatsilverGPX wrote:I can somehow see this guy getting confused and filling his engine up to the filler hole.
- bjk
- Totes
Re: BJK's '95 GPX
I may be mechanically inadequate, but I'm not that bad. If I'm that worried about it, I generally pay to get it done.silverGPX wrote:I can somehow see this guy getting confused and filling his engine up to the filler hole.
Or waiting until DIY days which are conveniently close.
