EL Glow Dials
- illmotion
EL Glow Dials
First it started to work sometimes and sometimes it didn't but now it has just completed stopped working.
I checked most of the fuses not sure what could cause it to stop working
the dial that i have is the one in this image http://www.ebay.com.au/itm/Mitsubishi-F ... 500wt_1268
any help would be appreciated and i don't know how to use a multimeter lol
- vipfto
Re: EL Glow Dials
will be the unit for power my first set of dials had this problem, basically just a resistor
Re: EL Glow Dials
Yup, would be the inverter. You can buy them off eBay for a couple of dollars.
Just search for "EL Inverter"
- illmotion
Re: EL Glow Dials
Ahhh there so many on eBay could you link me one that would suit it and is there DIY anywhere regarding putting the inverter in? Since previous owner put in the el system so I don't know what I am doing.Vectose wrote:Yup, would be the inverter. You can buy them off eBay for a couple of dollars.
Thank you that it simple problem I was worried for a moment lol
Re: EL Glow Dials
Would you be able to find the EL inverter and take a photo of it?
Just take out the cluster and follow the wires.
To install it, it's just unplug the old one and plug in the new one.
- illmotion
Re: EL Glow Dials
The EL Inveter is the black square thing behind my aircond duct?Vectose wrote:Would you be able to find the EL inverter and take a photo of it?
this is pretty much exactly from looking at it how mine was installed
http://www.completefto.com.au/completefto.asp?aid=493
- illmotion
Re: EL Glow Dials
Where did you get your resistor/inverter?vipfto wrote:will be the unit for power my first set of dials had this problem, basically just a resistor
- vipfto
Re: EL Glow Dials
Have had 3 sets of them now so got new one with each set. But is simple replacement part as above will find on ebay or jaycar should stock something
- illmotion
Re: EL Glow Dials
Wish we had a jaycar over here in WA lol, i did a search on ebay but not sure which one suits our EL Dials, could you possibly link one for me sorry for the trouble there just so many of them don't know which one the right onevipfto wrote:Have had 3 sets of them now so got new one with each set. But is simple replacement part as above will find on ebay or jaycar should stock something
- vipfto
