RPW Extractors- How to fit them?
Re: RPW Extractors- How to fit them?
shadowarrior wrote:Why is the fizz sound when i decelerate and the exhaust pop coming from under the car? Aren't they supposed to come from the exhaust end at the back of the car? *scratches head* :-/
I have this also happens when cold in certain revs
Naah, engine was hot. And it's usually when am driving around at a constant high rpm but not giving it enough throttle. Say stay on 3rd gear, at around 4k rpm...and do 90 for some time...then let go of the throttle You should get the exhaust pop. It's the fuel burning on the exhaust manifold or header and is normal. And damn I love that sound :P I have the same sound on my motorbike. The problem here is I think there is a leak somewhere along the exhaust system hence the pop is coming off the middle of the car instead of the back of the exhaust like it should.
Not sure what causes the fizzzsshhh sound when I let go of the accelerator though...seems like air sucking in.
The fizz is the section of flex pipe cavitating. You can shut it up by heat wrapping it.
Does the fizz do any damage? 'Coz I seem to like the sound :p
Also if there is a leak at the cat and flex pipe joint, can i leave it for a month or so till i get the high flow cat installed? Or will it cause damage if I drive the car now?
shadowarrior wrote:Does the fizz do any damage? 'Coz I seem to like the sound :p
If its after the O2 sensor then i dont think it will do any damage... just more of a loud annoyance to the public lol
I could be wrong though i didn't have a look at wikipedia :troll:
Hey Taz, this is what I was talking about. Any idea what the cable ties are attached to? They move, kinda swing....safe to drive around like that?
http://imgur.com/a/4dpex
Ah
Yes i remember - the Y pipe supplied did not have any mounting points for the rubbers so we zip tied them up to try and compensate :lol:
Long term solution is get a couple of mounts welded on to fit through the rubbers (simple job - shouldnt be too much) and while theyre there they can fix up that bolt if thats the noise you keep hearing
Probs wanna get it sorted for you start getting leaks around flanges from excessive vibration/movement.
I had a fucked mount towards the back not being mounted properly i kept blowing flanges and i went through two flex pipes.
silverGPX wrote:i kept blowing flanges
:cheeky:
silverGPX wrote:i blow
:cheeky:
Got Magnaflow 200 cell race hi-flow cat installed today along with the mounts welded and properly aligned. :)
shadowarrior wrote:Got Magnaflow 200 cell race hi-flow cat installed today along with the mounts welded and properly aligned. :)
:cheers: bet it sounds beast now
Sounds and feels brilliant :)
Next stop CAI and Intake pipe.
