Coolant leak
- Jase726
Coolant leak
So I was playing around with the car today when I noticed a leak from the right hand side. I had a bit of a look, but all I can see is coolant pooling on the edge of the sump and dripping down behind the compressor at a fairly consistent rate. There doesn't seem to be any hoses or such so I'm stressing a bit that it's coming from somewhere I don't want it coming from. Any one had anything similar? Looking for some good news.
- Jase726
Re: Coolant leak
Unless it's the water pump. As much as it would cost to get replaced anyways...
- vipfto
- kiz
- SA Coordinator
Re: Coolant leak
Yep second to thatvipfto wrote:water pump
1998 Mitsubishi FTO GPVR AERO
