6a12 to 6a13
6a12 to 6a13
what do i have to do to change my 6a12 to a 6a13
Re: 6a12 to 6a13
Re: 6a12 to 6a13
It's pretty simple... just swap the numbers bro
Re: 6a12 to 6a13
If you have to ask what to do, don't do it yourself. Get someone else to do it.
- spetz
Re: 6a12 to 6a13
It is the same as any other motor conversion.
The engine itself bolts in.
To my knowledge there are some clearance issues with the rear turbo, so some modifications are needed.
You can use your FTO gearbox.
You'd need a 6A13TT ECU. I am not entirely sure what the procedure here is but I would suspect that you plug it in though might need some additional wires, especially depending on whether your FTO is MIVEC or not to begin with.
There is quite a lot of info on this site already and some people have done this conversion so I am sure you'd be able to find everything out pretty easily
Re: 6a12 to 6a13
Sahin wrote:It's pretty simple... just swap the numbers bro
- kiz
- SA Coordinator
Re: 6a12 to 6a13
He's trolling....destinationtoby wrote:Sahin wrote:It's pretty simple... just swap the numbers bro
1998 Mitsubishi FTO GPVR AERO
- spetz
Re: 6a12 to 6a13
Easiest way to double your torqueSahin wrote:It's pretty simple... just swap the numbers bro
Re: 6a12 to 6a13
The bottom of the "2" is too sharp a bend compared to the curve on the "3". Which is what gives you the additional power and torque.
Re: 6a12 to 6a13
This!^^^ see these guys know whats up!Vectose wrote:The bottom of the "2" is too sharp a bend compared to the curve on the "3". Which is what gives you the additional power and torque.
And if you wanna be really crazy, change the 2 to a 4! i DARE you!
- spetz
Re: 6a12 to 6a13
Don't be crazy, leave it at 3.
