socket size required to remove the spark plug
Hi Guys,
wondering what socket number would i need to remove spark plug.
cheers.
cheers.
Re: socket size required to remove the spark plug
You need to either grind doen a tube socket or get a special mitsubishi spark plug tool thin enough to fit in. A regular soxket set wont fit
thanks Taz.
do you know what socket size is needed to remove the spark plugs?
cheers
cheers
- kiz
- SA Coordinator
Standard spark plug removal socket mate. It'll have the rubber insert for grabbing the plug. And just check your jack kit in your boot. Mine had the special tool hidden in there. So much easier than wrecking a socket if you have itNextLevel wrote:thanks Taz.
cheers
1998 Mitsubishi FTO GPVR AERO
Its the 16mm spark plug socket size. They do make other size plugskiz wrote:Standard spark plug removal socket mate. It'll have the rubber insert for grabbing the plug. And just check your jack kit in your boot. Mine had the special tool hidden in there. So much easier than wrecking a socket if you have itNextLevel wrote:thanks Taz.
cheers
- kiz
- SA Coordinator
I've never had a different sized plug, all the ones i've ever changed have always been the same oneBennoz wrote:Its the 16mm spark plug socket size. They do make other size plugskiz wrote:Standard spark plug removal socket mate. It'll have the rubber insert for grabbing the plug. And just check your jack kit in your boot. Mine had the special tool hidden in there. So much easier than wrecking a socket if you have itNextLevel wrote:thanks Taz.
cheers
I have 4 different sized plug tools at home, including imperial!
- spetz
Is the spark plug socket part of the FTO toolkit in the trunk?
Many of those kits would be gone by now me thinks. And no I dont think so actuallyspetz wrote:Is the spark plug socket part of the FTO toolkit in the trunk?
- kiz
- SA Coordinator
Na I don't believe they ever came out with the vehicle, but some lucky owners like myself may have acquired them with the vehicle from previous owners. Mine was in with my jack kitDaniel2019 wrote:Many of those kits would be gone by now me thinks. And no I dont think so actuallyspetz wrote:Is the spark plug socket part of the FTO toolkit in the trunk?
Pretty sure they did come with the tool kit.
Yes, it came with all mivec vehicle toolkits.spetz wrote:Is the spark plug socket part of the FTO toolkit in the trunk?
- kiz
- SA Coordinator
Well there we go . Question answeredBennoz wrote:Yes, it came with all mivec vehicle toolkits.spetz wrote:Is the spark plug socket part of the FTO toolkit in the trunk?
Just checked my fto tool kit....everything but the spark plug socket....FML.
Btw, how much is the going price for Iridium NGK BKR7EKC-N-11?
Anyone know?
Cheers
Anyone know?
Cheers
http://lmgtfy.com/?q=Iridium+NGK+BKR7EKC-N-11NextLevel wrote:Btw, how much is the going price for Iridium NGK BKR7EKC-N-11?
http://www.ebay.com.au/itm/6-x-NGK-Irid ... 257813410dNextLevel wrote:Just checked my fto tool kit....everything but the spark plug socket....FML.
Anyone know?
Cheers
Vectose wrote:http://www.ebay.com.au/itm/6-x-NGK-Irid ... 257813410dNextLevel wrote:Just checked my fto tool kit....everything but the spark plug socket....FML.
Anyone know?
Cheers
that is so CHEAP!!!! Wtf
It doesn't have the huge Australian mark up.
Hmm, I should look at getting a replacement kit... I have nothing for mine at all
hey guys, is Iridium supposed to be better than Platinum?
or is it the other way around?
