After sifting through mitsubishi.epc-data.com I have compiled this list of gearboxes that were available in the FTO.
Use this as a reference if you were wondering if you had a LSD or standard diff type. Your gearbox number is stamped on the top of the gearbox.
GPX (1994 - 1997)
Pre-Facelift 4 Speed Automatic
Code: Select all
Gearbox Part Number Date of Manufacture
F4A42-1-W7A1 MD974107 1994.09.1 - 1995.03.2
F4A42-1-W7A2 (LSD) MD974108 1994.09.1 - 1995.03.2
F4A42-1-W7A4 MD974349 1995.03.3 - 1995.09.3
F4A42-1-W7A5 (LSD) MD974350 1995.03.3 - 1995.09.3
F4A42-1-W7A7 MD974687 1995.03.3 - 1995.09.3
Facelift 5 Speed Automatic
Code: Select all
F5A42-1-E7A1(LSD) MD975920 1997.02.1 - 2000.08.3
F5A42-1-E7A MD975919 1997.02.1 - 2000.08.3
Pre-Facelift Manual 5 Speed
Code: Select all
F5M42-2-V7A1 MD974040 1994.09.1 - 1995.09.3
F5M42-2-V7A2 (LSD) MD974041 1994.09.1 - 1995.09.3
F5M42-2-V7A3 MD974602 1995.10.1 - 2000.08.3
F5M42-2-V7A4 (LSD) MD974603 1995.10.1 - 1997.01.3
Facelift 5 Speed Manual
Code: Select all
F5M42-2-V7A6 (LSD) MD975854 1997.02.1 - 2000.08.3
Pre-Facelift 5 Speed Manual
Code: Select all
F5M42-2-V7A2 (LSD) MD974041 1995.04.1 - 1995.09.3
Code: Select all
F4A42-1-W7A5 (LSD) MD974350 1995.04.1 - 1995.09.3
Code: Select all
F5A42-1-E7A1(LSD) MD975920 1997.11.1 - 2000.08.3
Code: Select all
GR, GR Limited, GR Sport (1994 - 1997)
Code: Select all
F4A42-1-U7A MD974106 1994.09.1 - 1995.03.2
F4A42-1-U7A1 MD974348 1995.03.3 - 1995.09.3
F4A42-1-U7A2 MD974686 1995.10.1 - 1997.01.3
F4A42-1-U7A3 MD975789 1997.02.1 - 2000.08.3
Code: Select all
F5M42-2-R7A MD974039 1994.09.1 - 1995.09.3
F5M42-2-R7A1 MD974601 1995.10.1 - 2000.08.3
Code: Select all
F5M42-2-V7A3 MD974602 1995.10.1 - 1997.01.3
Code: Select all
F4A42-1-W7A7 MD974687 1995.10.1 - 1997.01.3
F4A42-1-W7A8 MD974688 1995.10.1 - 1997.01.3
Code: Select all
F5A42-1-E7A2 MD975921 1997.02.1 - 2000.08.3
Code: Select all
F5M42-2-R7A1 MD974601 1997.11.1 - 2000.08.3
