Mitsubishi ASA prices
Hey guys,
Thought you might find this useful. I've got a price file that can imported in ASA for those that have it installed.
Price file can be found here:
http://ftoaustralia.com/downloads/ASA_prices.zip
Instructions: (it is assumed ASA is already installed)
1. Click File, then Setup.
2. Click the tab "Common 2".
3. Set "Price Data Reference" to "External Price Data".
4. Click OK (ASA will reset)
5. Click Data, then "External Price Update"
6. Browse for the file you want to use and select the currency required and press ok.
At this point it will load the file and reset ASA. You now have prices. If you ever want to switch between "Low Prices", "MSRP", or "Mitsubishi Prices", just follow steps 5-6 and select the other file.
For those that haven't got ASA & would like to use it, it's located here:
http://ftoaustralia.com/downloads/MMC_ASA_JAP_A.rar
http://ftoaustralia.com/downloads/MMC_ASA_JAP_B.rar
The instructions for ASA are in the first rar file.
Re: Mitsubishi ASA prices
There's an updated price file coming too. This one has has a few gaps & script errors.
Jawesome.
- fraz91
- Hair-do
Forgive my noobishness, but...
What exactly is this "ASA Prices" and what does it do?
ASA is the Mitsubishi After Sales Support program. Used by all Mitsubishi dealers, it has a complete database of all parts, pics & prices (and availability if you're on the Mitsi network.) I quite often use it to cross reference parts to other makes & models, plus it's also good for providing exploded parts diagrams etc.
It used to be called CAPS (Computer Assisted Parts Search) or similar.
Dwayne has a version of it running on Complete FTO as well.
Sweet, thanks for that!
- Shane001
Silly question, what currency is this in? And does it ignore import pricing lol!
Very handy additional reference regardless
You get to choose the currency when you put it in.Shane001 wrote:Silly question, what currency is this in? And does it ignore import pricing lol!
Good question! Not sure! Let me lookup something I know will have import markup...
- pearl_blu_fto
No worries
- Storm
Dancer, yet another reason to order more parts
I have just downloaded and installed ASA.
I have followed the install instructions including...
15. From within the crack folder on the root of the CD, copy mmData.dll to the programs install location ie E:\MMC\ASA\M00\PROG directory & overwrite the existing file.
16. Also from within the CD's crack directory, execute the MMC.REG registry file & allow it to make a change in the registry. It inserts the product key.
...and the program won't start up
I keep getting... "Key Expired" "This software requires registration !" "Enter Key"
Any ideas?
Any ideas?
- FTOwnage
I had the same problem when installing it. It is because ASA is a 32 bit program and if you are running 64bit you need to change the registry key that is being entered.
PM me with your email and I can send you the proper registry key.
Yep, need \wow6432Node\
