pleeeeeeeeeease help n light does not go out
Re: pleeeeeeeeeease help n light does not go out
Thanx dstocks back to the origanal q how would u check if the cables have broke or come loose
OP has a faggot title
No your torque converter is fucked lol.
If its not moving at all in any gear and the cable is being pulled down on the gearbox when u select gears, its stuffed.
If it was a sensor it'll just go in limp mode.
It gose into reverse would it still be the torque converter
