Need a new or second hand radiator for the gpx
- Chiinkstarrh
Re: Need a new or second hand radiator for the gpx
Ive got one
^ as above, or alternatively you can get new aluminum Feonix radiators off ebay for around 300 delivered.
- Chiinkstarrh
sounds good hard to install ? or need a mechanicTaz wrote:^ as above, or alternatively you can get new aluminum Feonix radiators off ebay for around 300 delivered.
- BorepYano
shout just bolt up right?Chiinkstarrh wrote:sounds good hard to install ? or need a mechanicTaz wrote:^ as above, or alternatively you can get new aluminum Feonix radiators off ebay for around 300 delivered.
Direct replacement.
The only difference structurally is the top indent. Slightly more 'box' like, and thus the slam panels (if you even have one) will need slight modification to fit, but for an ordinary fto - its 4 bolts and two clips.
Dont forget to connect your hoses back up
- BorepYano
this guy...Daniel2019 wrote:Dont forget to connect your hoses back up
- Chiinkstarrh
thanks guys lol just thinking about buying this black gpx with broken radiator
