Hi, up for sale is my set of work emotion cr wheels. They are 18x8.5 +30 offset all round. I have a 5mm wheel spacer in the front and a 10mm bolt on spacer on the rear to make it flush with the side of the car. Wheels are wrapped in Federal 595 225x35 tires 95% tread. Rear wheels have small chips from the front wheels throwing up stones.
What you get for $1800 is 4Xwheels and tires, blue wheel nuts, 5mm spacer, 10mm bolt on spacer.
Rear guards needs to be rolled. Not sure if wheels clear standard shocks as I'm running coil overs.
Wheels have no gutter marks.
work emotion wheels FS $1800
- fto-007
- fto-007
