Make the trailer bigger?
So, should I keep the doors in the FTO Trailer?
Spotted this posted on the Magna forum.
- bjk
- Totes
Re: Make the trailer bigger?
That is just the most confusing thing. It's like, "Hey, we need some more practical space to carry things. Except let's make it low enough that we might leave the trailer behind at a speed bump."
Would be pretty long though. And would it matter that the wheel is further back then?
Yes it, does.bjk wrote:Would be pretty long though. And would it matter that the wheel is further back then?
The wheels need to be at a certain point on the trailer for it to be deemed worthy.
By the looks of the shots, they have turned it in to an entertainment area, I can see a TV top, so it's more a mini caravan.
But yeah, good luck on speed bumps.
- bjk
- Totes
I'll just leave this here.Astron_Boy wrote:Yes it, does.
Despite knowing next to nothing of trailer creation, I'm assuming it's probably not worth the effort to move the wheel forward, and likely have to cut into the door itself to do so?
The whole point of the trailer is to have it look like the rear end of an FTO.bjk wrote:I'll just leave this here.Astron_Boy wrote:Yes it, does.
- bjk
- Totes
I know that, but you don't necessarily need it to have the doors! If Astron wants to put in the extra effort, then good on him.Vectose wrote:The whole point of the trailer is to have it look like the rear end of an FTO.bjk wrote:I'll just leave this here.Astron_Boy wrote:Yes it, does.
I was referring to your moving wheels statement.
- bjk
- Totes
I still don't understand what you mean.Vectose wrote:I was referring to your moving wheels statement.
I was saying moving the wheels isn't a good idea because the whole point is to have it look like the rear end of an FTO. Also would be way too much effort.
^ to the power of 110.Vectose wrote:Also would be way too much effort.
Not my worst, but fair enough.bjk wrote:I'll just leave this here.Astron_Boy wrote:Yes it, does.
- bjk
- Totes
That's what I was saying as well. Which is why I made the comment about how far back they'd be.Vectose wrote:I was saying moving the wheels isn't a good idea because the whole point is to have it look like the rear end of an FTO. Also would be way too much effort.
You want the wheels to be at about the half way point of the center of the trailer.
They will allow a discrepancy, or if the trailer design is purposed with twin axles etc.
But in the above situation, it's like a wheel barrow, all the weight is at your arms, or in the cars case, the tow ball.
You don't want to be putting all the weight on the tow ball, you want it balanced.
- aza013
- NSW Coordinator
Agree with your above post Dan, you need to look at the balance point of the trailer. If the above trailer in the pic was able to be regoed I would love to get the number of the engineer that past it . Most RMS inspectors would defect it in a heart beat.
Heaps too much.
- Kustom
:kustom:
- bjk
- Totes
Kustom wrote:Yolo
finally found a suitable time to use that one.
Totes!bjk wrote:Kustom wrote:Yolo
- bjk
- Totes
Astron_Boy wrote:Totes!bjk wrote:Kustom wrote:Yolo
