WTB: GPX Front Calipers
- ObsidianRadio
Hey all,
After a set of GPX front calipers.
If anybody has a set lying around, let me know with your asking price. I'm sure we can come to an arrangement!
Cheers
Cheers
Re: WTB: GPX Front Calipers
Kinda hard to find actually. Took me a little while to source mine...
- bjk
- Totes
Really? Mine were really easy to find.Daniel2019 wrote:Kinda hard to find actually. Took me a little while to source mine...
Helps when they're already on the car.
Should have probably sourced the calipers before buying rotors.
- bjk
- Totes
Don't worry, it just means Tim doesn't have to do them all on the same day.Vectose wrote:Should have probably sourced the calipers before buying rotors.
- ObsidianRadio
I like to think ahead. Bought the rotors so they're ready when I find the calipers.
In the shed they go
In the shed they go
- vipfto
And who said doing them all anyway?bjk wrote:Don't worry, it just means Tim doesn't have to do them all on the same day.Vectose wrote:Should have probably sourced the calipers before buying rotors.
Might just do a DIY when I do mine
One already exists, so saves you even doing that.vipfto wrote:Might just do a DIY when I do mine
- bjk
- Totes
Astron_Boy wrote:One already exists, so saves you even doing that.vipfto wrote:Might just do a DIY when I do mine
But I could stand to learn how to do it. If you're there to make sure I don't somehow end up doing it incorrectly and inadvertently end up off a cliff because I can't brake.
- fto-007
Still looking for front calipers? I have a set with standard rotors at home if your interested?
- ObsidianRadio
Yeah bud, still looking!fto-007 wrote:Still looking for front calipers? I have a set with standard rotors at home if your interested?
I got the rotors from the group buy, hence why I'm looking for calipers
- fto-007
No worries ill have a set off a gp VR where are you located You can have them for$100 Plus Postage
- ObsidianRadio
Adelaide, dude. That'd be AMAZING!!fto-007 wrote:No worries ill have a set off a gp VR where are you located You can have them for$100 Plus Postage
