Error 22,32
Error 22,32
Hey guys just a few questions. I'm getting engine code errors 22-crank angle sensor and 32-vacuum sensor.
The car is also not idling correctly it's constantly revving up and down. I'm guessing the stepper motor?
Or could the chasing at idol be cause by the faulty sensor as above?
And is there a way to test the sensors? or would u recommend just replacing them?
thanks in advance
thanks in advance
Re: Error 22,32
It's probably your crank angle sensor or your vacuum sensor.
- Chebus
Re: Error 22,32
cant argue with logicSahin wrote:It's probably your crank angle sensor or your vacuum sensor.
Re: Error 22,32
Well replaced the crank angle sensor.
Been searching for a vacuum/map sensor and don't seem to be any in Australia.
Anyone have a second hand one??
Or is there another mitsubishi using the same part I could order?
Re: Error 22,32
Well now iv replaced the crank angle sensor and the map sensor. Only to find that both waring lights are still there disconnected the battery for 15mins too reset, but didn't go away Do they need to be removed with the mitsubishi scan tool/computer??
Also it's still chasing at idle, only when first started. Ordered a new stepper motor see if that stops it.
Re: Error 22,32
Hmm. any updates on this?
Where are our vacuum sensors?
Re: Error 22,32
TPS is out of adjustment then.
Re: Error 22,32
lol
Re: Error 22,32
U what ben
Re: Error 22,32
waht
Re: Error 22,32
Well its idling funny because of your vacuum error code. If you are getting a crank angle sensor reading i doubt the engine is running. Yes the fto shares the same map (vacuum) sensor as the 1.5L lancer/mirage. Hopefully this will fix your problem.
