Tip Shifter
- SchumieFan
Tip Shifter
if anyone has a Tip shifter they dont want,
the plastic flaring that runs along with the shifter when you move it (the bit that covers up the holes)
-mine is brittle and falling apart, if someone has this spare they probably dont need the whole shifter - a lot easier than pulling it apart and replacing the plastic)
Cheers
Cheers
Re: Tip Shifter
I have one although I'm using it on the smurf when I change my shifter.
dstocks should have a few.
- SchumieFan
Re: Tip Shifter
Thanks Daniel!
You're so helpful!
You're so helpful!
Re: Tip Shifter
You're welcome mate!
Re: Tip Shifter
Diddly.
Re: Tip Shifter
The f**k am I reading...
Ask for Lawsos knob flange.
He won't be using it.
- SchumieFan
Re: Tip Shifter
I did, even went round to his house, his is fkd too
Re: Tip Shifter
teehee.
Re: Tip Shifter
I'm not sure what the thing is u are after, but.... I am pulling out all the tip shifter gear tomorrow to replace with the manual shifter.. So if u can get a photo of what u need, ill check to see if I have it, and then let you know
Re: Tip Shifter
You'll break it loldestinationtoby wrote:I'm not sure what the thing is u are after, but.... I am pulling out all the tip shifter gear tomorrow to replace with the manual shifter.. So if u can get a photo of what u need, ill check to see if I have it, and then let you know
Re: Tip Shifter
There are 3 parts to the shifter.
The leather exterior
the plastic button
The ring inbetween those 2 parts.
The ring is what Schumie is after.
You pop the button out with a flat blade on either side, then there is 2 or 3 small phillips screws holding the ring in.
the plastic button
- SchumieFan
Re: Tip Shifter
Ring? I need the slidey blank plate that covers the slot
Mailed your LED'S by the way
Re: Tip Shifter
As I said.. A picture would help or ill throw some up after I remove the gear.. And you can point out what it is lol.
Mailed your 18year old stock bulbs today aswell
- SchumieFan
Re: Tip Shifter
I'll post a pic when I get home
Re: Tip Shifter
OH, That!
Hmmm, can't remember if I gave my spare one to AJ or not...
Re: Tip Shifter
He is after the thin plastic bit that fits under the panel with the plus minus and D, N, etc. They commonly break. There is a chance I may have an unmolested one, but not sure.
- SchumieFan
Re: Tip Shifter
this fkd bit!
Re: Tip Shifter
Looks fine, just sticker bomb it broooooooo
Re: Tip Shifter
Sahin wrote:Hey toby where did you get your sticker bombing sheet from? I wanna do a few things and your one is cool...
Sorry schumie, I don't have that on mine.
Re: Tip Shifter
Ask AJ if he installed his... I'm next to positive I gave my spare to him.
Meanwhile, it wasn't perfect, but it's in 1 piece.
Having said that, you can buy them from Mitsubishi new.
Simply say you have a Magna sports with tip shift.
