FS SYD: FTO GPX Racecar Part Out V2
See new thread here.
viewtopic.php?f=2&t=28854
Re: FS SYD: FTO GPX Racecar Part Out V2
SOLD LIST
Engine
Flywheel, Clutch & Pressure Plate
Rear brake rotors and calipers
Rear trailing arms inc hubs and lower control arms
Handbrake cables
Megan Racing rear toe & camber arms
Bonnet and rear boot.
Custom oil cooler and oil filter relocation kit. Includes 19 row oil cooler, oil filter relocation and custom oil lines and brackets to suit the FTO.
Facelift front bar with custom brake ducting, reo, indicators, silver alloy mesh and a GoPro camera mount.
Radiator with single thermo fan
Sparco Pro 2000 race seat
eManage Ultimate Kit inc Innovate O2 sensor, modified plenum & 65mm throttle body, and 210cc injectors.
Manual short shifter
HEL braided brake lines including bolts.
GPX front lower control arms modified with brackets for GPvR front droplinks.
GPvR 20mm front sway bar with polyurethane bushes and GPvR drop links.
Polyurethane front control arm bushes - VGC front and rear (rears new pre Bathurst).
Cusco Alloy Front Strut Bar.
Black race seat mounted with Bride adjustable seat rails.
Sparco 6 point race harness with CAMS expiry 2018 (for non International events).
Headlights.
Manual dash cluster.
Tail lights.
5sp Manual gearbox with Cusco LSD and 4.625:1 gears.
Speedy Holotype-R 17x7+38 5 Spoke Silver Alloy Rims inc Dunlop 215/45-17 Race Slicks.
Adjustable Alloy Rear Strut Bar.
Pair 27 spline GPX manual drive shafts.
GPX spark plug tool / timing belt tensioner adjuster / tappet adjustment tool / MIVEC rocker piston check screw.
Side window wind deflectors.
Tein Type HA Coilovers with adjustable front camber tops.
Extractors.
Brembo Sport Slotted front brake rotors.
6 point bolt in roll cage by Bond Roll Bars including side intrusion bars and padding.
GPX electric mirrors.
GPX Starter Motor.
GPX Front Hubs (not ABS).
Brake booster with 1” master cylinder.
Pair GPX Front Control Arms.
Edit: See above ;)
ill grab the oil cooler and relo kit :)
silverGPX wrote:ill grab the oil cooler and relo kit :)
No worries, you'll be looking around $20 to $30 for postage to Qld. There is a bit of weight in it and it'll need a fairly large box so as not to put a bend in the hoses. If this is OK please confirm and I'll pm my bank details. So say $220 posted pending packaging.
Good to Go.
No worries, pm sent :)
Good to Go.
vanadinite
Post by vanadinite »
PM Sent! :)
Before I make any more f***ups, anyone who wants anything please post replies here, but I need to go back through pms tonight to see if anyone has previously requested any of the parts still for sale.
From tonight on, replies in this thread will get preference over pm's only, to keep things transparent. Please reply here then pm.
vanadinite
Brake lines sold. Pm sent!
Question: Does have different gear ratios affect highway RPMS?
silverGPX wrote:Question: Does have different gear ratios affect highway RPMS?
Yes. 100kmh in fifth with standard gears is around 3000rpm, with these gears it'll be around 3200rpm.
You will notice the increase in acceleration though. Will launch much faster :twisted:
vanadinite
Is the GPvR Sway bar and Control Arms all a kit? sway bar, arms etc? And does it include sway bar bushes and mounting brackets?
And if so SOLD! pending postage estimates hehe
vanadinite wrote:Is the GPvR all a kit? sway bar, arms etc?
This would need to be a courier pickup as the sway bar will be too long for postage. Also going to be a pretty big and heavy box with the control arms.
Why don't you throw it on the pallet with the gearbox ;)
vanadinite
Does it include sway bar bushes and brackets?
Ill probably get all the stuff ive bought so far on a pallet and sent with e-go
Shane001 wrote:Why don't you throw it on the pallet with the gearbox ;)
Trying hard I see :lol:
vanadinite wrote:Does it include sway bar bushes and brackets?
Yes, all poly bushes including the control arms.
vanadinite
Ok then, ill call you tomorrow about organising postage and stuff. but yeah man its sold, i was gonna do front bushes and links in the next few weeks anyways and these have only seen short track times (a few thousand kms track is nothing compared to 100 000kms of road use :lol: ) and i have been hunting a bigger front sway bar for ages, never realised the gpvr ones were 20mm compared to the GPX's 16mm.
More pics and items added.
Sparco seat is sold.
However I have another black race seat similar to the Sparco that I'd bought for a passenger seat for ride days, but realised most of my passengers won't fit in it lol! So I'm going to bundle this with the Bride seat rails for $300. I'll put up some pics of this later today.
