Help needed from GR owners
- shadowarrior
- Tightarse
So the Maf sensor in your GR. You unscrew those two bolts beside the electric connector...then how do you pull the sensor out? There was a plastic guard on top of the sensor held by clips, took that off and that exposed a metal plate shielding the circuit board of the sensor. But how do you pull the damn sensor out...don't want to break stuff
- shadowarrior
- Tightarse
Re: Help needed from GR owners
Need to clean MAF sensor of the Pajero. Don't want to take out air box and clean the sensor from inside....thought it could be pulled out after unscrewing those small screws, clean and put back in.
The sensor is in the pipe itself? Unplug it and take that section out?
- shadowarrior
- Tightarse
Yeah in the pipe, just after the air filter. Going to do that. couple of clamps and that part comes out straight.
Get a new MAF lol dat amayama
- shadowarrior
- Tightarse
Geez! ThankssilverGPX wrote:Get a new MAF lol dat amayama
-start of diagnostics-
Patient: "Doctor, I think I sprained my arm"
Dr. SilverGPX: "Just chop if off and get a new bionic arm!"
-end of diagnostics-
Patient: "Doctor, my 5yr old kid has a fever"
Dr. SilverGPX: "Just kill it and make a new baby!!"
- bjk
- Totes
That's totally unrealistic.
Matt could never get a doctorate.
- shadowarrior
- Tightarse
LMAO!!!
- payaya
You can't! The pins are soldered in and exverything is basically sealed inside and it's not meant to be opened.
There's nothing to clean in there anyway.
There's two sensors in the pipe part just spray thrm.
