Error codes
Error codes
It's telling me two codes
Two 2 second flashes
Four 1 second flashes
http://www.youtube.com/watch?v=lKoCNVBDxPs
Anyone know what they are?
- FTOwnage
Re: Error codes
24 Vehicle speed sensor
Someone correct me if I'm wrong.
http://ftowa.com/html/workshop/workshopart07.html
- FTOwnage
Re: Error codes
The codes will cycle through and repeat.
For example say you have two error codes. 12 and 24.
It will do one long flash and two short flashes (12) and then it will do two long flashes and 4 short (24).
It will then keep repeating.
Re: Error codes
So it's 1 code cycling or 2 codes ?Vectose wrote:The codes will cycle through and repeat.
Re: Error codes
What's that mean ? Sensor isn't pluged in or broken or whatFTOwnage wrote:24 Vehicle speed sensor
Re: Error codes
You didn't video for long enough, but it looks like...
2 long + 4 short repeating = code 24 repeating
Re: Error codes
I was just using the codes for reference. As Phil said, video wasn't long enough. But they will just keep cycling. If it's one then it will keep repeating the same sequence. If multiple it will show each code as mentioned above then repeat.
Re: Error codes
PHIL069 wrote:You didn't video for long enough, but it looks like...
Bit It's repeating that over and over...
What's a speed sensor???.
Re: Error codes
What's in the video is what it repeats .. There's no others. it Just pauses for abit then starts again
Re: Error codes
Speed sensor is on the top of your gearbox towards the back of the car, not the reverse light switch further back but simular looking.
Error 24 =
- Malfunction of the speed sensor
- Improper connector contact, open circuit or short-circuited harness wire of the speed sensor circuit
- Malfunction of the engine ECU
Error 24 =
Re: Error codes
PHIL069 wrote:Speed sensor is on the top of your gearbox towards the back of the car, not the reverse light switch further back but simular looking.
Error 24 =
Thanks ill check it out tomoro and see if its all plugged in properly :/
Re: Error codes
I am wrong
The vehicle speed sensor is in the "V" of the engine. It's connector is inbetween two of the injector connectors. The two injectors on the front bank to the passenger side of the engine.
I will look for a pic soon
Re: Error codes
I was right to begin with
The electrical manual doesn't show placement very well.
So disregard the second description and go with the first one
Re: Error codes
Hahaha awesome ! ThanksPHIL069 wrote:I was right to begin with
Re: Error codes
Its on the gearbox, near the firewall, black plug.
Re: Error codes
silverGPX wrote:Its on the gearbox, near the firewall, black plug.
It's plugged in.............
Re: Error codes
Stepper motor plugged in?
Its on the same loom.
Sensor could be dodgy, also try reseating the whole plug. You may not have pushed it in all the way.
Did engine light light up in white car?
Re: Error codes
Its also fused as well
Fuse No: 8 in the interior
Re: Error codes
And by repeating I mean taking the 10mm bolt out removing whole sensor, check if any damaged cogs, I believe u could also use the one out of your auto box if u still have it
