Error codes
Re: Error codes
That's not the one at the back
Re: Error codes
Yep same loom, manual ecu, stripped back the plug and wired the black/yellow to the black/red, then put spade connectors on the red/blue & black/silver, then connected those two to the reverse sensor.. Speedo never worked. But reverse lights were working fine, until recently. Found the blown fuse 3 yesterday, replaced but still no reverse lights..and still no speedoDaniel2019 wrote:Did you use your auto loom? Did you hook up the two wires that turn your reverse lights on properly?
Turn the aircon on and off . And this is the code/codes I'm getting. http://youtu.be/_e8-Z7RI5XU
Re: Error codes
Error code 24 I think
