As the title says, I'm thinking of an engine swap. Nothing radical, just swapping my 1995 GR and 1994 GPX.
What are the things I need to be aware of?
Engine Swap
- 95Xena
Re: Engine Swap
Non mivec and mivec engines have different ECUs and wiring looms.
Isn't difficult to swap them, although thats as far as I have got yet. Still not up to the bit where I have to plug it all in and hope it doesn't go kaboom.
Although it's a bit of a pain in the ass to fit the loom through the firewall (not a euphemism) had to get Vectose to help me.
- 95Xena
Re: Engine Swap
I figured it would be fairly simple Just wanted to get some facts if I needed them before I gave the cars to the mechanic. No way I'm doing it
Re: Engine Swap
Yeah, just loom and ECU was far as I know..
The only part of the loom that you need to change from what I'm aware is the part the goes from the ECU through the firewall.
- BorepYano
Re: Engine Swap
but.. why?
- 95Xena
Re: Engine Swap
Because it will be cheaper to swap out engines than do all the things to the GPX that I have got on the GR already.
And because I can so
- BorepYano
Re: Engine Swap
fair enough
