Hi all
I am after a starter motor and an alternator for 94 GR does anyone know where i can get this for less than $300 each?
also a quick question. Are mitsubishi galant starter motor the same as FTO cause they are a lot cheaper than the fto ones on ebay
Starter Motor and Alternator
- Taiwo
- BorepYano
Re: Starter Motor and Alternator
have you looked into getting them reconditioned? I'm sure my starter motor was reconditioned for under $150.
- Taiwo
apparantly mine is completely gone said the mechanic
I have starter motor + alternator available. Both used, but both working. $70 for the starter and $100 for the alternator, can do both for $150.
Edit - sorry, my bad. Alternator won't fit. Starter might though.
- Taiwo
thanks Dan i just bought from dwayne yesterday
No worries.
- Taiwo
do you know why the alternators don't fit dan? the two pin i got doesnt fit
Errrr no clue. GR is 2 pin and GPX is 4 so should fit unless you got a 4 pin.
