C clips for selector bracket + shift pattern sticker
Private Sales Only
Hey guys need the C clips that hold the gear selectors into the bracket.
Also need a little shift pattern sticker for blue slip. That or a gear knob with H pattern on it to either buy/borrow.
Preferrably Sydney pickup!
Re: C clips for selector bracket + shift pattern sticker
Im having trouble telling the difference between auto clips and manual ones. Not sure if they are different or not.
    Bobby has H pattern.. So thats sorted..
    dstocks wrote:Im having trouble telling the difference between auto clips and manual ones. Not sure if they are different or not.
    Auto doesn't have any that I could see... although I think it would only have the one. I suppose if you can have a look at the ones you have on the Lorax or the Aero that would tell you, alternatively I'll try and dig up a pic online.
    And awesome, cheers Craig.
    For reference, I found the clips here (U clips apparently!) - http://www.camskill.co.uk/m3b0s12p1159/ ... LL_FTO%5Cs
    Part numbers are
    MB367526 - Manual
    MB307554 - Auto
    I sent a selection yesterday. Hopefully they will be helpful
      dstocks wrote:I sent a selection yesterday. Hopefully they will be helpful
      Sent a PM an hour or so ago with a pic attached to check if there happened to be any of them in there :D
      Thank you!
      I think there shouldbe oneor two
        You're the best! :D
