Cheap parts for sale
- Connor_1994
Okay guys so I have a whole heap of parts that I need gone quick as possible
Whatever doesn't go soon I'm going to take to the tip or something to get it out of mums house.
This is a short list of the main things people will be interested in.
If you after something in particular let me know and I'll see if I've got it
I'll ad some prices off the top of my head but I'm negotiable on prices
So the short list contains items as such.
Brake booster
Tail lights, mint condition set $100
One set with a chip $50
Rear rocker cover
Intake plenum
Windscreen reservoir
Coolant over flow bottle
Battery cradle and support frame
Sump pan
Standard intake pipe
Bones release cable and bonnet latch
Abs brake system
Clutch master
Manual gearbox cable
Manual shifter
Handbrake and switch
2 rear bars
Rear bar rheo
3 right hand guards
Left hand guard
2 skittles panels
Black boot lid and spoiler
Indicator and fog lights 2 sets $60 each
Side skirts with end caps
Fuel cap and.filler inlet
Fuel cap cover
Steering column and firewall surround
Assortment of pedal set ups
Assortment of interior pieces
Boot/fuel release cables
Gpvr air con controls
Air con boxes for under the dash
Voltmeter gauge
Hazard light switch
Door kick panels
Combination stalk with airbag
Assorted seatbelts
Child restraints
Inner boot carpet that covers the tail lights
The centre piece that hold the clock and volt meter dials
Windows switch
Rear inner lower quarter trims
Aireial cable
Tacho surrounds
Manual dash
And Cusco adjustable coilovers that would suit a rebuild just for safety - around $700 ono, there $2k new for a set if you can get them anymore
I know there isn't many prices but if your after something let me know and I'll come up with a price
I'm negotiable on prices as I need them gone quickly or I'll just have to dump them
Can't have them all lying around mums house lol
I'll post some pictures in the comments
Brake booster
Rear rocker cover
Intake plenum
Sump pan
Abs brake system
Clutch master
Manual shifter
2 rear bars
Rear bar rheo
3 right hand guards
Left hand guard
2 skittles panels
Fuel cap cover
Voltmeter gauge
Hazard light switch
Door kick panels
Assorted seatbelts
Child restraints
Windows switch
Aireial cable
Tacho surrounds
Manual dash
- Connor_1994
Re: Cheap parts for sale
Also a fuel pump for a facelift model with the plug attachment instead of the threaded type
And a fibre glass reinforced carbon fibre bonnet from dwayne that does need some work, just needs some glassing to fix some cracks etc
Just let me know if your after anything and we can work something out
I need this stiff gone pretty quick guys
- Connor_1994
Actually I don't know where I came up with 700 for the coilovers, must be way too tired
Ive been thinking lately around the 400-500 mark, but like I side I don't mind I just want them gone, I can get a quote to refurbish them if you like, to get them back to new condition
When it comes to that let me know and you can post all the smalls to me, I will pay postage.Connor_1994 wrote: or I'll just have to dump them
Better than dumping it all.
- Connor_1994
Okay Phil
When it gets close to that time I'll try and box everything up the best way possible and let you know
Your'e a good bloke.
I will then have moar spare parts to help out others too.
- ZFL45H1
Duuuuuddeee the sump arrived today.... Buts it a sump off an auto transmission case I needed an oil sump from an engine f**k!
- shadowarrior
- Tightarse
Just use duct tape
A friend with with a lancer is chasing GPVR front LCA's do u have them Connor.
- Connor_1994
Silver gpx (matt) you decide to run your mouth on my facebook post and then you block me off both of your accounts, and im guessing have blocked me from messaging you on the forum aswell as that action is not available for you but is for eveyone else,
i do not have gpvr lower control arms, if i did i would have sold them to someone last week, i do however have gpx lower control arms
Inbox must be full on forums. Part wasnt for me.
- shadowarrior
- Tightarse
Connor_1994 wrote:Silver gpx (matt) you decide to run your mouth on my facebook post and then you block me off both of your accounts, and im guessing have blocked me from messaging you on the forum aswell as that action is not available for you but is for eveyone else,
Hey mate, what's your fb account? You in the FB group?
- Connor_1994
Yeah I'm on the Facebook Page, look for my parts or roll cage post, you should be able to find me that way
- shadowarrior
- Tightarse
Found you.
