FTO won't crank - NOT starter motor
- FTEvolution
Re: FTO won't crank - NOT starter motor
When I say cramped, it's mostly because of the mandrel bent intake and intercooler piping.. It's very well made, and very effective flow wise, but it takes up a hell of a lot of space and makes getting to that side of the engine a nightmare.
Smooth and sleepy
Smooth and sleepy
- FTEvolution
God help me if I ever need to change the transmission filter haha
Smooth and sleepy
Smooth and sleepy
Bah, sounds like soft excuses to me. I change whole transmissions annuallyFTEvolution wrote:God help me if I ever need to change the transmission filter haha
- FTEvolution
Soft excuses is right, but here's another.. Car is a long way away and I need to cycle there and any time I need to work on it, also parts shops are a long ways away and I can't be arsed wasting that much time lol
Smooth and sleepy
Smooth and sleepy
- FTEvolution
Update (potentially)
Two sparkies and a mechanic are adament after speaking to me that the issue is with the ignition tumbler
Questions;
1, are all FTO ignition tumblers the same?
2, is there anything I need to know to remove it? My car doesn't have air bags. Anyone done it?
Further checking has confirmed that the earth cables I can get to are fine.. Assuming that I can trust the multi meter that is..
Questions;
Smooth and sleepy
Smooth and sleepy
- FTEvolution
Also, we don't have transponder keys do we? My car didn't have keyless entry prior to the alarm install
Smooth and sleepy
Smooth and sleepy
Nope. We don't have transponder keys.
- FTEvolution
Thank god for that! Any idea how to get the tumbler out? Is it as simple as other Mitsubishi? I'm assuming it is
Smooth and sleepy
Smooth and sleepy
From memory it's pretty simple.
- payaya
I think ya heading in the wrong direction. When it doesn't start check to see if the starter is getting power then go from there.FTEvolution wrote:Update (potentially)
Questions;
- FTEvolution
Yeah, wrong direction lol..
I'm now leaning towards the inhibitor switch because I've always had problems with it
Smooth and sleepy
Smooth and sleepy
- FTEvolution
Question.. If connect up a rudimentary switch between the starter solenoid and the battery, will this bypass everything else and potentially start the car? Assuming the ignition is on of course..
Smooth and sleepy
Smooth and sleepy
- FTEvolution
Bypass the solenoid is what i mean.. But yeah, weeks like to completely isolate the ignition system, it does have an immobilizer after all
Smooth and sleepy
Smooth and sleepy
- FTEvolution
Thoughts on supplying power directly to the solenoid? The starter is definitely getting power. So sure it's the inhibitor switch :S
F'n stupid car!
F'n stupid car!
Smooth and sleepy
Smooth and sleepy
Wouldn't it be easier to remove the inhibitor and restore the wiring back to factory?
- FTEvolution
Care to explain what you mean?
Ignition wiring is factory. Inhibitor is factory. I haven't bypassed anything yet. I'm not near my car, hence I'm trying to find options to try get the damned thing moving. The bypassing of the solenoid is to start it so I don't need to tow the bastard from where it is.
In fact.. any ideas of how to bypass the inhibitor switch? I don't see external wiring in the vicinity, but thinking about it, surely there is a way to add a switch to that system..
Smooth and sleepy
Smooth and sleepy
Thread revival!!
Did you ever find out what was the problem?
It's looking like it's the brushes in the starter motor, replacing them today and will go from there.
