tacho not working
tacho not working
I have a 94 fto and want some one to shead some light on y my tacho is not working
Re: tacho not working
Faulty IFS - Ignition Failure Sensor (this is the most common issue)
or
Bad wiring connection
or
Faulty tacho gauge
or
Faulty cluster
or
Faulty cluster circuit board
or
Faulty ECU
or
or
Faulty tacho gauge
or
Faulty cluster
or
or
Faulty ECU
Itll be the Ignition Failure Sensor.
PHIL069 wrote:Faulty IFS - Ignition Failure Sensor (this is the most common issue)
or
or
Faulty tacho gauge
or
Faulty cluster
or
or
Faulty ECU
Orr a mystical evil witch doomed your tacho to never work agin. No matter what you do. It will never, work,again!
Like mine
LOL but we cant use you as an example. You broke the laws of averages toodestinationtoby wrote:PHIL069 wrote:Faulty IFS - Ignition Failure Sensor (this is the most common issue)
or
or
Faulty tacho gauge
or
Faulty cluster
or
or
Faulty ECU
Like mine
Where is the IFS located and where can i get a new one
