R-Spec MIVEC Controller wanted
Private Sales Only
Rob Furniss
Post by Rob Furniss »
Anyone got one and want to part ways with it?
Re: R-Spec MIVEC Controller wanted
Rob Furniss wrote:Anyone got one and want to part ways with it?
I have one.. Somewhere in the garage.. Not sure of its condition..
Rob Furniss
Sorry mate I don't need now so don't go hunting round the garage for it.
No probs...
Had a quick look before.. Couldn't find the bloody thing.. But still do have a lot of boxes there... Have been dreading doing the garage clean up, and luckily the Evo/GSR is still at the mechanics... So haven't had to do it.......
....Yet..... :lol:
Rob Furniss
I was only after the harness bit anyway, was going to hack it to death to use for the emanage but i've bought a boomslang harness that's fully plug and play.
It was my bad wiring that was the problem with over-fuelling when I had the supercharger on, only found out after I had replaced the O2 sensor and still had the problem, then removed everything to do with the charger (except the emanage) and still had the problem, wiggled the wiring to the emanage and it went crazy so I removed the emanage and put the old injectors back and no more problem but also no more supercharged FTO.
I've gone back to the start and been redesigning the brackets and intake, taking my time with it to get it right and this time and I decided no chopping and splicing of the factory harness, the boomslang was expensive but I will rest easy knowing that bit's taken care of.
When is the EVO back?
Not too sure on that one at the moment...
Been struggling with the 5 stud conversion... But should have that sorted out soon ... ish ...
Got the new cam gears the other day, and the rocker cover is finished so just need to pick that up ... Then put it all back together... So will be a little while yet, as have to re-do the manifolds, and make the exhaust legal as well ... Got the Flex Fuel adapter, and am seeking injectors at the moment...
So my 750cc's will be up for sale...
Rob Furniss
Just been right through your build thread, what a journey, well done mate.
Rob Furniss wrote:Just been right through your build thread, what a journey, well done mate.
Thanks mate... She is getting there ... With the new cam's and rocker cover I want to be able to push the boost up a tad more .. So will now start to look at tuning.. With the last rocker cover, when I would wind the boost up past 15psi, I would start to get oil leaks from where the attachment was to the catch can.
Nothing big, but just enough to annoy me, and give that lovely burning oil smell ...
