i was searching on the forum and couldn't find it, but most likely as im a noob at searching.
i did however find this not sure if its the right code for a GR
NGK Platinum (PFR7M)
http://www.ebay.com.au/itm/6x-NGK-Plati ... 53f37b1b7c
and these
NGK iridium (BKR7EIX11)
http://www.ebay.com.au/itm/6-x-NGK-Irid ... 257813410d
i cant be bothered pulling my plug out to check so hopefully someone can steer me in the right direction.
also read on gpxs that the rear plugs may be different to the front? as i have a gr not sure if its the same or not?
cheers
Spark PLug code for GR
Re: Spark PLug code for GR
never mind i found it on the NGK website iridium BKR6EIX-11
