Learn how to change your water pump
- SchumieFan
Okay...
So next Sunday I will be changing fresh's water pump,
It's a bit annoying so if anyone in Sydney wants to learn/watch feel free to join in, otherwise I will be taking pictures and eventually making a DIY... Once I get to Queersland.
Hit me up if you want to learn open heart surgery
- Dras
Re: Learn how to change your water pump
- SchumieFan
I've got no Internet and not much data left on my mobile at the moment so I'm avoiding you tube at the moment but I picked up a few tricks when I did mine... so if anyone wants a looksie
I would like to learn how to do it.
please do take photos, it would be handy!
- vipfto
I would love to learn how lol
How many of you guys use the actual special tool by Mitsubishi to tighten your cambelt tensioner?
i used a pair of circlip pliers lol
I dobumpak wrote:How many of you guys use the actual special tool by Mitsubishi to tighten your cambelt tensioner?
- vipfto
You're welcome.PHIL069 wrote:I dobumpak wrote:How many of you guys use the actual special tool by Mitsubishi to tighten your cambelt tensioner?
- SchumieFan
I followed the workshop manualbumpak wrote:How many of you guys use the actual special tool by Mitsubishi to tighten your cambelt tensioner?
I won't lie I also use the circlip remover haha.
I just don't do water pumps.
- payaya
Me too. I don't know how you c**nts use circling pliers to get the tension required! You guys must let the hydraulic tensioner make up for the slack which itself is bad for the tensioner.PHIL069 wrote:I dobumpak wrote:How many of you guys use the actual special tool by Mitsubishi to tighten your cambelt tensioner?
Also all mechanics know it's a pain in the arse not to have the tool sometimes! Especially when ya juggling the cam spring tension, belt and everything else by yourself! But they always go missing!!
