Car Bouncing
loidsam86
Car Bouncing
Post by loidsam86 »
Hi guys...I got Mitsubishi FTO 1994 (Auto)....I am having big problem in my car...My car is bouncing too much...I feel like I have flat tyers...I have been to couple of mechanics but they said there is no problem in this car...Dont know what to do....Please guys give some suggestions...Thanks
Re: Car Bouncing
Sounds like your shock/spring combination (suspension) is too firm. Do you have coilovers or aftermarket shocks and springs? Aftermarket suspension can be substantially harder than factory, leading to a bumpy ride on roads that are uneven. Also, what size rims are you running and what it the profile on your tyres. 18" rims with a 35/40 profile will make for a fairly hard ride as well. The factory rims are 16" which are quite abit softer.
    loidsam86
    Re: Car Bouncing
    Post by loidsam86 »
    First of all thanks for reply...
    Tyers size is 215/40ZR18
    and rim size is 18X8 5/114.3 45M
    Recently I went to Bob jane for wheel alignment and i told them that car is bouncing...They checked and asked me whether I cut the springs to decrease the Height...
    Re: Car Bouncing
    215/40/18s are going to be very harsh, suggest going to a 17 inch wheel with a higher profile (225/40 or 215/45 or higher)
    You probably also have hard aftermarket springs. Have a look and see what color your springs are and what kind of shocks you have. May need to swap your springs.
    loidsam86
    Re: Car Bouncing
    Post by loidsam86 »
    do you know from where to get springs ? Thank you...
    Re: Car Bouncing
    KYB Excel G are the go:
    Front L: 334154 Front R: 334155 Rears: 341140
    Available from practically anyone that stocks suspension and are reasonably priced.
    Make sure you dont have coil overs before you buy though as this is just the shocks and not springs/strut tops. As Daniel said,17" rims will make a big difference too.
      loidsam86
      Re: Car Bouncing
      Post by loidsam86 »
      Thanks...
      Re: Car Bouncing
      Excel Gs are shocks.
      I'd be getting a set of king springs if I were you.
      loidsam86
      Re: Car Bouncing
      Post by loidsam86 »
      Will try that...SO I am bit confused now...sud I change Tyres first then Shock absobers ?
      Re: Car Bouncing
      OK, heres a summary:
      - Changing the wheels/tyres will definitely help as the greater the rim size, the harsher the ride. 17's are the best balance between handling and comfort.
      - Changing the springs will help IF the ones you have are aftermarket and stiff or have been cut. If the coils of the spring are black then then they are mos tlikely factory and there is no point changing them.
      - Changing the shocks will help IF the ones you have are aftermarket and stiff or buggered. The Excel G shocks are a good balance between comfort and handling and the closest youll get to factory ride.
      A normal strut setup has 3 components, the shock, the spring and the strut top. These can be replaced individually. IF you have coilovers however, all 3 bits are wrapped up in a single part and all 3 must be replaced.
      Hope this helps
        loidsam86
        Re: Car Bouncing
        Post by loidsam86 »
        Got it...Thanks
        Re: Car Bouncing
        Yep +1 on what dstocks said.
        Re: Car Bouncing
        Also, if you are looking for new springs, try and search for progressive springs. Makes the car way smoother for daily drive and long trips.
